Header or Camshaft??
Old Jun 1, 2009 | 01:12 PM
  #31
03Sleeper's Avatar
finch basically covered everything. I lost some low end power when I went with headers, just fyi. My car is a bit slower pulling from a stop.
Old Jun 2, 2009 | 06:44 PM
  #32
falkore24's Avatar
Originally Posted by falkore24
Both have pros and cons. On a 4 cylinder accord, I don't recommend headers for a DD because you lose some low end drivability due to less low-rpm torque. With a camshaft, the car will be retuned to make power at higher rpms, hurting the idle performance a bit, plus then you will also need engine management to tune the car.
For the camshaft, a Stage 1 or 2 shaft should retain some drivability. Cams are usually for larger builds such as turbo or a built NA.
Old Jun 3, 2009 | 01:26 PM
  #33
03Sleeper's Avatar
i mean falkore.
embarrassing.
My ADD kicked in when i saw finch in your sig.
02BlueAccord
Jan 25, 2007 02:17 AM
Shadow1992
Jan 23, 2007 02:48 AM
Shadow1992
Jan 23, 2007 02:47 AM
Shavel
Dec 20, 2006 02:26 AM
deserthonda
May 12, 2006 12:12 AM
