high flow cat
Old Oct 11, 2007 | 01:32 AM
02BlueAccord's Avatar
Default high flow cat
have a 2002 accord with h/i/e and if i put on a obx high flow cat will that make my car have less power because it will be to much air? thats just what i have heard, or will it give me a lil bit of a gain?
Old Oct 11, 2007 | 03:35 AM
Shadow1992's Avatar
Default RE: high flow cat
The more air your exhaust, including the cat, can flow, the better. You'll see a little bit of a gain with a high flow cat versus OEM.
Old Oct 11, 2007 | 07:15 AM
falkore24's Avatar
I'm not sure that an OBX cat is really any higher flow than OEM. The only true performance cat that I know of for Hondas is Random Technologies.
Old Oct 11, 2007 | 07:58 AM
marbro's Avatar
and have a hefty pricetag for an RT cat...... but you get the best possible from it
Old Oct 11, 2007 | 10:31 AM
oh ok cool. so i would see a lil bit of an increase? cuz i heard from someone if you have too much aire flow without boosting then it will actually lower your hp a lil bit
Old Oct 11, 2007 | 11:54 AM
falkore24's Avatar
that's true with regard to the pipe size. The cat is just a point restriction, which is best to be minimized ..... the problem is that if it's too little of a restriction, it is not performing it's function of converting exhaust gasses to water, CO2 and N2.
Old Oct 11, 2007 | 03:45 PM
ya see i have a 2.5in down pipe and i was thinking if i got the cat it would be to much air flow
Old Oct 12, 2007 | 12:04 PM
falkore24's Avatar
If you mean a 2.5"cat-back as well, the restriction could be helping you as mentioned. The real problem is that the flow is too slow through a 2.5" cat-back from a 4-cyl.
Old Oct 12, 2007 | 03:32 PM
Fenix's Avatar
But, from what ive been reading here, it will help in the top end, right?
pyaarawala
Jun 1, 2007 01:19 PM
ohiostatepimp22
May 1, 2007 09:35 PM
TedsF23accord
Apr 8, 2007 10:22 PM
BLuEPiTBuLLz
Jan 23, 2007 01:02 AM
bpo145
Aug 5, 2006 01:11 PM
