Intake for Accord 2004
Old Mar 20, 2008 | 10:22 PM
kouken's Avatar
Default Intake for Accord 2004
Looking for Intake along withits pipefor Accord 2004 Automatic. Can somebody recommend one? How much power it can increase? Does it has a huge suction sound?
Where can I find the installation manual to replace the OEM intake?
Thanks
Old Mar 25, 2008 | 07:04 PM
RTexasF's Avatar
Super Member
Default RE: Intake for Accord 2004
AEM, maybe 3-4 HP, suction sound - no
Old Mar 26, 2008 | 09:19 AM
falkore24's Avatar
Directions come with any name brand intake. Basically take the black plastic stuff out and pu the new tube in.
Old Mar 26, 2008 | 11:00 AM
00AccordLX5spd's Avatar
Registered User
Instructions can also be found in the DIY section
Old Mar 26, 2008 | 11:15 AM
klrspz's Avatar
Tons of info about your questions already exists on the forum... Please do a little bit of research before posting questions like these.
Also, some will argue that taking the bumper off is unnecessary, but i strongly suggest it as it will probably cut your work-time down by ~50%.
And before you ask more questions, do yourself a favor and read these:
- http://hondaaccord.wikidot.com/intake-info (based mostly on the faq directly below this)
- https://www.hondaaccordforum.com/FAQ...m_22712/tm.htm (Located in this forum btw, should have been the first thing you read)
Old Mar 27, 2008 | 11:42 AM
kouken's Avatar
Thanks for the responses, guys. I was looking at K&N brand and told thismodel 69-1206TP due to mine does not have mass air flow sensor. (http://www.knfilters.com/search/prod...Prod=69-1206TP).It requires to disassemble the inner fender valence, and believe for the intake filter. however, WhenI looked at the OEM, it does not seem that way. Thefilter is ontheengine "surface". AmI lookingit correctly?
Also,from the attached pic, what is that connection plugs nearthe bottomend of the plastic pipe near the engine? What about those near the upper end near the filter?
Thanks again, guys.
Old Mar 27, 2008 | 12:22 PM
falkore24's Avatar
You didn't use the search function. If you have a question that hasn't been answered I'd be very surprised.
andrew7673
May 30, 2010 06:08 PM
mchris176
Jan 13, 2010 01:21 AM
sharad024
Jul 29, 2007 10:24 PM
JerseyTuscani
Jul 2, 2007 05:21 PM
1stAccord_2ndHonda
Jan 22, 2007 05:13 PM
