Intermittent Check Engine Light P0420
Old Nov 17, 2012 | 10:26 PM
jiggygad's Avatar
Default Intermittent Check Engine Light P0420
Hi All,
I have 2007 Honda Accord VP 4cly manual with a check engine light that comes on for a few days and then turns of for a couple weeks. When the light goes on, I went to Autozone to get it checked and they say its the P0420 code "catalytic converter inefficency". I even had the dealer do a diagnostic and they said the samething. Although I am not convinced. The car does not idle rough at all. And notice not performance degration. In fact, I even cleaned my throttle body, air mass flow sensor and injectors and seen a performance boost.
  • Why would the check engine light go off?
  • While the O2 sensors have their own codes, could it really be an O2 sensor malfunction causing a faulty catalytic converter code?
  • Also I use premium (93 octane) gas. Can this be an issue?
Thanks!
Old Nov 18, 2012 | 10:22 AM
The code does point to the converter. I would inspect the exhaust system for any leaks in the system as this can cause the readings between the two O2's to be out of spec.
anticrom
Aug 3, 2013 10:20 AM
PiksPal
Dec 31, 2010 10:03 AM
carl2782
Dec 4, 2010 05:54 PM
ajluu
Sep 28, 2007 01:10 PM
