New to headers and SRI/CAI
Old Sep 24, 2007 | 11:21 PM
Fenix's Avatar
Default RE: New to headers and SRI/CAI
ORIGINAL: falkore24
4-2-1 is better for low-end than 4-1, but the stock will still have better off-the-line torque. 4-1 will offer the most gains above 5000 rpms.
That was the only part i understood
Old Sep 25, 2007 | 08:58 AM
falkore24's Avatar
Velo .... I have one also and I've also seen theories pointing both ways, but I looked at the Reynold's number that represents the airflow in my intake and it is so far turbulent that it seems impossible for the swirl caused by the spacer to last more than an inch. The only thing that I see as possible is that by adding volume to the IM that the resonant frequency is lowered a little. Since the intake, TB, spacer and IM are not tuned together, there is very little chance that the spacer will cause resonance in the IM that will improve power.
Old Sep 25, 2007 | 10:28 AM
Velocifero's Avatar
there's only one way to know for sure.
Old Sep 25, 2007 | 11:25 AM
falkore24's Avatar
True, but I'm not going to waste time, money and effort on with/with-out dynos on a part that I don't really think does anything. By calculations, it can only add restriction.
If you do the dynos, let me know what you find!
Old Sep 25, 2007 | 11:34 AM
falkore24's Avatar
ORIGINAL: Fenix
So whats really the deal with the headers? seeing that they have to bolt into the stock exhaust manifold position and then bolt onto the stock cat, how can it really increase performance, if its basically got the same diamiter? Is it just less restrictive? Similar to getting a hi flo cat? or is the matieral its made of what increases performance? Or is it the 4-2-1 design?
Working backwards, we've already addressed 4-2-1 vs. 4-1. If you mainly keep rpms above 4000-5000, 4-1 is better. 4-2-1 is better for 2000-5000 rpms. The material makes very little diference in power. Theoretically, the ceramic coating keeps the exhaust stream hotter and thus faster, but I wouldn't expect the difference to be measurable on a car that is not highly modified (forced induction, high compression, etc.). Primaries can be larger even if not noticable by eye leading to less restriction. Improved collector = less restriction.
03Sleeper
Jun 7, 2014 09:26 AM
TyWoz91
Apr 6, 2012 03:53 PM
jasonfridlund
Jun 24, 2009 02:37 PM
honda5o7
Apr 4, 2007 02:01 AM
vtecHef
Feb 24, 2007 09:49 PM
