Replacing 03 accord air filter
Old Apr 28, 2008 | 11:09 AM
jarede7's Avatar
Default Replacing 03 accord air filter
Can anyone give me some help on how to replace my air filter on my 03 accord?
Old Apr 28, 2008 | 12:13 PM
jarede7's Avatar
Default RE: Need help Replacing 03 accord air filter
I read some other posts and it seams that it is recommended to remove the rubber hose leading to the air filter from the throttle body instead of from the box housing the air filter. Can anyone confirm this? Please Provide a tip?
Old Apr 28, 2008 | 12:27 PM
klrspz's Avatar
this is a fairly easy process...
It won't hurt to remove the rubber hoses; just unscrew the clamps some before-hand and they should squeeze off with some elbow-grease..
other than that, it should just be open the box, and swap the filters...
I have a CAI on my 03-4cyl pretty much as soon as I got the car, so I've never even changed a filter from the stock box to give you 100% step-by-step process...
but as I said, it's really really simple, most cars are identical in process which involves a few screws or simple clips to come out and you have full access to the filter.
I'd be hard-pressed to imagine you being able to mess anything up if you just went for it.
Old Apr 28, 2008 | 12:46 PM
jarede7's Avatar
Thanks I will give it a another try. Ive never worked on my car before but it seems like there is very little opportunity for damage with this type of replacement!
Old Apr 28, 2008 | 01:38 PM
KevinAccord's Avatar
step 1: locate filter box
step 2: locate 4 clamps
step 3: open the clamps
step 4: remove top cover to the side
step 5: (remove old filter)
step 6: put new filter (i assume i didn't have to write the "going to the store to buy a filter" part)
step 7: close top of box
step 8: close the clamps:
step 9: close hood (not really necessary)
step 10: turn on car
And there you go...
Old Jun 4, 2010 | 11:02 PM
g22cd5's Avatar
Supper Moderator
You don’t need to remove it. Makes no sense b/c the hose is connected to the top of the air box. You open the air box at the middle...that where its splits open to get to the air filter.
Old Jun 5, 2010 | 02:29 PM
On a 2003 4-cyl, the top of the filter housing extends just a bit under the sheetmetel of the left fender. Removing the hose makes it easier to open the filter box. Or not. Personally, I found it a bit easier if I loosen the big hose, but it's not a tremendous difference.
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
satutoring
Jul 28, 2009 03:41 PM
olslomo
Apr 18, 2007 04:53 PM
adbraz
May 31, 2005 12:03 AM
