1994 accord with an f20b Red line issues.
Old Dec 2, 2019 | 11:07 AM
jake0157's Avatar
Default 1994 accord with an f20b Red line issues.
Hey guys looking for some help with my f20b swapped accord. Currently the car refuses to rev over 6k rpm. No check engine light is on, it has a Chipped p28 ecu with an f20b base map and a red line set to 8k rpm. When i was using a weird *** p13 chip it would only go to 5500. Does it sound like a fuel issue?
Old Dec 2, 2019 | 11:34 AM
The Toecutter's Avatar
Originally Posted by jake0157
Hey guys looking for some help with my f20b swapped accord. Currently the car refuses to rev over 6k rpm. No check engine light is on, it has a Chipped p28 ecu with an f20b tune and a red line set to 8k rpm. When i was using a weird *** p13 chip it would only go to 5500. Does it sound like a fuel issue?
Welcome to the forums. Right off hand I don't think it's fuel, as the fuel system is designed for a larger engine. I think you might want to talk to your tuner, and see if the problem is in the ECU. I only say that, as t sounds more like a timing issue than fuel to me.
Old Dec 2, 2019 | 12:03 PM
jake0157's Avatar
How can you determine if its a timing issue? And the map it has on it should be good according the the tuner.
Casper Young
Jun 13, 2019 05:07 PM
hippohat
Sep 10, 2018 09:45 PM
rleckey
Jan 26, 2014 01:25 AM
simplified
Feb 19, 2008 11:14 AM
dinzer
Aug 9, 2005 11:17 AM
