1994 Honda LX problems
Old May 23, 2008 | 06:49 AM
Stevie3D
Default 1994 Honda LX problems
I have a 1994 Honda Accord LX which isidling/running rough
It was running just fine then the symptoms started.
I have checked and have the following:
Timing is correct
Compression on all 4 cylinders
Spark to all four cylinders
Checked wire, distributor cap and rotor and are all OK.
Spark plugs are gapped correctly but appear all carbon soot.
All the fuel injectors appear to be firing.
With the car running I can pull wires from cylinder 1 and 4 and there is no change im performance. When each wire from cylinder 3 & 4 are pulled are will stall out.
No check engine light on and no codes are stored .
Any help would be greatly appreciated.
Old May 23, 2008 | 10:39 AM
Mikey182
Default RE: 1994 Honda LX problems
check your altenator that could be it get new wires and spark plugs it may runfine but there is a flaw try that!
a.clout
Apr 26, 2015 04:07 PM
louiricc
Mar 19, 2013 05:49 PM
HondaNatey
Mar 11, 2011 12:06 PM
hondas only
Aug 31, 2007 09:05 AM
KimberlyC
Apr 16, 2006 11:51 AM
