1997 Window Wiring Harness
Old Aug 7, 2016 | 11:38 PM
Potastew's Avatar
Question 1997 Window Wiring Harness
This is hopefully short and simple. I've got a 1997 accord, 4 door, 4 cylinder automatic and my front passenger window stopped going down. I think I traced it down to no continuity on the Blue with Yellow stripped wire that runs between the Window Master Control on the driver door to the passenger door window switch. What I'm unable to find is if this wire has any connectors between these two switches or if it is a direct run. If there are any connections can anyone point them out, and does anyone know where I can download wiring schematics?
Any help you can provide is greatly appreciated.
Old Aug 8, 2016 | 10:18 AM
BBB Industries has free access to TSB's and wiring diagrams.
BBB Industries - TSB's & Wiring Diagrams
Connector ID and Wire Harness Routing diagram from 1994 manual shows a connector in driver's kick panel and in door.
Problem is frequently in the door to door jam jumper w/ rubber boot. Fatigue damage occurs to wires.
Old Aug 14, 2016 | 03:14 PM
Potastew's Avatar
Thanks for the information. I pulled the connection off at the drivers side door jamb and found the wire in question had broken off at the connector. Pull in out of the connection, resoldered and everything seems to work god now. It was a little tight got it done.
Thanks
timgeorgi
Mar 2, 2008 06:12 PM
nugen
Sep 4, 2007 03:28 PM
jerij
Aug 13, 2007 09:35 PM
calenatar
Feb 12, 2007 10:18 PM
Tarsis
Jun 8, 2006 06:23 PM
