2007 Accord PO141 Trouble
Old Feb 22, 2020 | 02:08 PM
meltonk1's Avatar
Default 2007 Accord PO141 Trouble
I have the PO141 on my 2.4l Accord. I have replaced the bank 1 sensor 2 oxygen sensor, cleared the codes and fired it up. Codes come back in 30sec. So, I checked the plug and wiring and so forth, all looks good.
With the key in run or with the engine running, I checked the following.
The car side wiring harness plug of the O2 Sensor there is a white/black wire that is going to the heater. I checked the voltage on the wire going to the heater and have 13volts. There is a green wire that is ground to the heater, it is dead, no volts not grounded.
I plugged in the old O2 sensor to the harness and started up the car. The sensor did not heat up. I grounded the green wire with a jumper and then I could see the O2 Sensor turn red and of course burn my hand.
So, I am guessing the green wire back to the ECU is bad. Broke or whatever.
Short of pulling everything out of the car, how do I trace that back to the ECU.
Old Feb 23, 2020 | 02:04 AM
Seanjordan20's Avatar
What brand sensor did you put in
Old Feb 24, 2020 | 07:45 AM
meltonk1's Avatar
Desno
Dennis19
Nov 7, 2018 04:21 PM
Adler
Aug 24, 2012 05:44 AM
Chris K
Jul 7, 2012 02:07 AM
tightshark2001
Oct 28, 2008 11:36 PM
MartaH
Feb 27, 2006 09:44 PM
