How to change o2 sensor
Old Oct 26, 2008 | 10:57 AM
tightshark2001
Default How to change o2 sensor
I need information on how to change the primary o2 sensor in a Honda Accord 4 cylinder 2001.
Old Oct 26, 2008 | 12:19 PM
finch13's Avatar
Default RE: How to change o2 sensor
Step 1: Unplug the greay 4-wire connector on the transmission housing running the the O2 sensor in the exhaust manifold.
Step 2: Saturate the O2 sensor with penetrating oil/WD-40/ or the like. Don't do this if you plan on reusing the sensor, I don't know if that will foul it.
Step 3: Using a oxygen sensor socket or the correctly sized wrench, remove the sensor.
Step 4: Replace sensor with a new sensor. Not sure if you can apply anti-seize compound on the threads.
Step 5: Watch your gas mileage over the next few tanks to make sure it's within normal range to make sure the sensor is functioning properly. Also, make sure the CheckEngineLight doesn't come on.
Old Oct 28, 2008 | 11:36 PM
ORIGINAL: finch13
Finch has the install down right..dont need anti sieze on the threads cause it come with it already on the threads..Thanks Finch [sm=smiley32.gif]
pondrun
Nov 8, 2021 09:40 AM
62maxx
Oct 18, 2015 08:20 AM
chris h
Apr 3, 2011 10:01 AM
62maxx
Nov 21, 2006 12:04 PM
