2014 accord blower fan noise
Old Dec 8, 2017 | 09:47 AM
Harryo78's Avatar
Default 2014 accord blower fan noise
Hello,
I'm new here. My 2014 accord lx has been great so far! However this morning I started hearing a chirping noise coming from I'm guessing the blower fan, located on pasanger side under glove box. I can hear it when the radio is on, just the kind of thing that can drive me crazy on my commute. Anyone have any suggestions for a remedy? Any comments Thanks in advance!
Old Dec 8, 2017 | 10:17 AM
Harryo78's Avatar
Pt.2 2014 accord lx 4 cyl., cvt
Old Dec 8, 2017 | 12:10 PM
Chirping sometimes indicates worn bushings on the fan motor allowing armature to strike permanent magnets. It can get to an hair-raising squeal w/ time.
Fix is motor replacement.
Old Dec 8, 2017 | 12:18 PM
You might be able to see something if you drop the glovebox (as if you're changing the cabin-air filter). The blower is directly under that filter, & I think you can remove the blower downwards into the forward end of the passenger footwell. Probably have to remove a trim panel or something.
Old Dec 8, 2017 | 12:55 PM
I should have added that chirp could be blower cage hitting the shroud. Loose bearing would be most likely.'
redbull-1
Aug 10, 2014 12:06 PM
Honda Man For Life
Apr 9, 2012 09:38 AM
dthomp99
Jan 5, 2011 06:53 PM
accordfan
Feb 10, 2008 10:26 AM
anothervietguy
Dec 13, 2007 08:52 PM
