Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
Easy way to test that interior Fan Blower Motor works (2003 – 2014 Accords):
Old Aug 10, 2014 | 12:06 PM
Default Easy way to test that interior Fan Blower Motor works (2003 – 2014 Accords):
The following are to easily test that the interior fan motor is not the source of the problem when the interior fan blower does not blow air. You may want to first check that all respective fuses are not blown.
2003-2007 Accords
1. Locate the blower power transistor under the passenger dash.
2. Unplug the electrical connector to the transistor unit.
3. Attach a jumper wire (short piece of wire) from the Blue/Black wire cavity to the Black wire cavity on the unplugged electrical connector. Leave the connector unplugged.
4. Turn the ignition ON. The blower motor should run.
2008-2012 Accords:
3. Attach a jumper wire (short piece of wire) from the Green wire cavity (terminal no. 4) to the Black wire cavity (terminal no. 2) on the unplugged electrical connector. Leave the connector unplugged.
2013-2014 Accords:
3. Attach a jumper wire (short piece of wire) from the Green wire cavity (terminal no. 4) to the Black wire cavity (terminal no. 3) on the unplugged electrical connector. Leave the connector unplugged.
19962door
Jan 13, 2015 07:53 AM
MrBones
Jan 27, 2012 11:00 AM
deserthonda
Mar 12, 2007 02:30 AM
92Inspire
Aug 4, 2006 12:49 AM
