93 honda accord heating issues...
Old Jul 22, 2011 | 02:27 PM
AKHAN's Avatar
Default 93 honda accord heating issues...
Ok..so I just bought 93 Honda Accord Ex with 182K miles for my wife. Prior to purchase, everything was in working order. Well, now i have overheating problem. My mechanic has advised that i changed the radiator, which he did along with Temp guage. I got the car back and notice that temp is still rising little bit more than 3/4 when idle and then drops back to the middle when it's driving. Took it back to the mechanic and he did see temp going up then coming down. First I thought fans were not working...but they are. AC works so does the heater. Head Gasket was replaced at 172k miles when timing belt was done...so not sure what is going on..anyone with suggestions?
Old Jul 22, 2011 | 03:02 PM
bigpat's Avatar
Almost A Senior Member
When the timing belt was changed, did the mechanic also replace the waterpump and thermostat ? Hopefully the waterpump isn't the original one...Open the radiator cap and start the engine, does the water/coolant circulate when at the normal temp ?
Old Jul 22, 2011 | 03:39 PM
AKHAN's Avatar
The water/coolan is circulating at the normal temp....thermostat was replaced when i got the new radiator.....waterpump don't know...but i would think it was replaced....how can I diagnosed the water pump?
Old Jul 22, 2011 | 06:06 PM
bigpat's Avatar
A few things to look for to indicate a faulty waterpump:
Open the hood and listen to the area of the pump for any bearing noise...Howling or grinding sound from the impellor of the pump.
Examine the ground under the engine compartment for any signs of leaking coolant from a bad waterpump seal. Look on the lower part of the engine block as well.
Double check that the water/coolant is reaching the heater core. Run the heater or defroster with the fan on to be sure.
If you can contact the shop that did the timing belt, ask them to verify that the pump was also replaced, as this is typicallly when it is done. Even though the coolant is circulating, I would want to know for sure.
Good Hunting !!
Old Jul 24, 2011 | 01:31 AM
BigPat has given you some good information there, so follow it up and and see what has been done to that car...
stavrich
Apr 18, 2015 05:59 AM
johnwiechel
Sep 24, 2013 05:07 AM
mandycae
Sep 5, 2012 06:35 PM
osaio
Dec 20, 2010 08:33 AM
CEJLG541
Mar 8, 2008 04:49 PM
