Aftermarket metra DDin stereo install turned my accord into a 1 ton paperweight
Old Mar 29, 2019 | 10:32 PM
Brock Johnson's Avatar
From: MINNESOTA... Land of 10,000 salt covered hondas
Default Aftermarket metra DDin stereo install turned my accord into a 1 ton paperweight
Hey everyone so heres the info/waking nigbtmare that is my life.... i recently installed a double din JVC dvd/CD player w/blutooth into my 06' Honda Accord EX 4d 2.4l using a basic metra t harness kit. Before someone says it " yes I disconnected the battery, soldered and heat shrunk my connections, reset the radio code, checked all my fuses, andbread chicken soup for the hondas soul to it every night...etc.. The metra I used requires the factory stereo to remain for climate controls while the after mark sits where the center console pocket was. I turn the key and all systems are go, both stereos wok fine however the car will not turn over or even click. So I ran through testing the battery which was faulty but still under warranty... to keep this short... new duralast gold battery and gold plated terminals/ new ground wire. Reamed the terminals and cleaned the grounds as well as dremelled off the paint on the frame for good contact. Ran a scan and i only got a single DTS... 92-20 SRS indicator fault to ground. Now i know hondas can be touchy when it comes to wiring but i cant find anyone online that has the hazard/airbag indicator module causing a no start situation. Any advice is appreciated... p.s. ive checked all the relays and checked for voltage and continuity in the battery cables and relay box. im currently in the middle of stripping it down so i can benchtest the starter. Probably worth mentioning i changed out the battery ground to frame for one of those silver braided performance grounds and the battery metered at 12.01 with no key turn. Thought maybe the two stereos are drawing to much for the starter to crank... help please before i become one of those ford fuzion assh@|€s lol
Old Mar 30, 2019 | 09:23 AM
shipo's Avatar
As a suggestion, please rewrite your post using sentences, paragraphs, and punctuation; what you wrote above will be ignored by most folks as unreadable.
Old Mar 30, 2019 | 03:03 PM
The Toecutter's Avatar
When you changed out the battery ground wire, does it connect to both the body AND the engine/trans? Did you try jumping the starter before pulling it? If it all worked before the radio swap, then it should still work unless you unplugged something else. Double check your work.
Glacier point
May 4, 2014 12:21 AM
dcaz
Jul 24, 2013 04:13 PM
itsfrito
Dec 5, 2012 12:04 AM
EJiK
May 15, 2011 09:28 AM
jprez1980
Apr 3, 2007 02:57 PM
