Help needed
Old Aug 28, 2019 | 06:58 PM
Beater without a heater's Avatar
Default Help needed
I have recently become the proud owner of a 96 accord that needs a lot of TLC. I'll start with the engine codes: air/fuel ratio too lean, o2 sensor because no cat, speed sensor. The abs light and srs lights are on. I'm not sure why the abs light is on but I can hear the pump kick on when I start the car, but then it stops and the abs light comes on and the brakes seem very weak. I replaced all the brake pads and flushed out the old fluid and it's alot better but it still feels weak. When I changed the oil I noticed the cv axle boot was torn and had lots of gunk in it. When I go over a speed bump at 5 mph or less the whole bounces and i can hear the sound of metal on metal. I know the suspension is done for and I want to replace it so that I don't lose a tooth every time I hit a pothole. If someone could list all the parts for the entire suspension system I would appreciate it, and would like some help diagnosing the abs problem.
Old Aug 28, 2019 | 09:30 PM
This "new member" area is mostly for welcome & introductions. Normally I'd just move this to the forum area where it belongs, but this time I'll ask you to separate the different problems & search in "General Tech" whether something is already there. We don't really forbid new members from posting in the forum area in the topic you need.
I think putting the engine codes in one post in General Tech, the suspension problems in the Suspension forum area, etc. will be less confusing for us to deal with.
Tompkinswest
Feb 7, 2019 01:14 PM
Dennis19
Nov 7, 2018 04:21 PM
scratch
Feb 10, 2012 06:24 PM
93 Accord Driver
May 30, 2011 11:02 AM
birdmanmdp
Sep 19, 2008 07:31 AM
