lucas oil treatment??
hey i had a small chatter on bottom end of engine so i put some lucas oil treatment in it and now it sounds like my engine is knocking??? any ideas as to what happened? Before i had a little knock on cold starts like maybe a bearing was bad or going bad but after the lucas oil treatment i dont know what happened, it sounds worse.
Oil treatments, regardless of brand, are a waste of money. In your case, it sounds like the engine had already reached the end of its useful life, and the viscosity change in the oil due to the Lucas treatment simply pushed it over the edge of a pretty big cliff. At this point your best option would probably be to buy a used motor from a junk yard and put it in. Good running motors for your car are inexpensive and plentiful.
yea my uncle said it spun the bearing that was already bad being the lucas treatment is so thicker than oil. Thing is i just bought a 93 lx just for the motor and it ran fine
(no knocking or tapping at all, no oil light, nothing) when i bought it. So i swapped engines and now this? What did i do wrong when changing engines to make it do that?
compiler
Oct 17, 2013 04:42 PM
