need help P0171 and P0174.
Old Mar 5, 2021 | 09:59 PM
Andy3500's Avatar
Default need help P0171 and P0174.
My 2011 accord v6 80k miles ,Engine had been re rings at @ 55k miles also timing belt and spark plug air filter was replace same time .today it getting P0171 and P0174 S0 far i already check vacuum leak inspect hose .air sensor clean .Air filter .......i need help and any advise . Thanks
Old Mar 6, 2021 | 04:40 PM
Seanjordan20's Avatar
You're running lean. Clean MAF, check fuel trims and O2 sensor). It could be a few things causing it (O2, fuel pump, MAF, leak, etc). Have you done a smoke test?
Old Mar 6, 2021 | 10:24 PM
Andy3500's Avatar
i never done smoke test .(i do not have smoke machine) the car hard to start when it sit over night but when engine run it smooth no shanking. When engine warm up it run and start up fine .at this point i did not think fuel pump or vacuum leak, the most i think something go wrong with my MAF sensor .Thank a lot for help .
carid
Apr 29, 2015 09:07 AM
98_accord2011
Jun 3, 2011 06:45 PM
april18
Apr 2, 2008 07:41 PM
PAhonda
Feb 17, 2008 10:48 PM
finch13
Aug 19, 2007 09:08 PM
