04 TL supercharger fits on 03 accord v6.
Old Jun 3, 2007 | 10:58 PM
rhrhkdals's Avatar
Default 04 TL supercharger fits on 03 accord v6.
Looking forward to get the 04 comptech supercharger for my 03 accord v6.
Mine is automatic trans ... can i install the supercharger with automatic trans?
One of my buddy told me that i need to modity the radiator...
What does it mean by modity the radiator? like bigger radiator?
Can i install intercooler on supercharger?
Anyone installed the supercharger on your accord?
Helps are appreciated.
Old Jun 9, 2007 | 04:42 PM
03Sleeper's Avatar
Default RE: 04 TL supercharger fits on 03 accord v6.
Use the search function.
You can do supercharge./turbo on A/T...but you have to be careful....
Old Jul 25, 2007 | 09:05 AM
trojanhorse's Avatar
yes, the comptech TL supercharger will fit on your accord. but it is not a direct bolt on kit. there are a few things that need to be done
1) modifying the radiator is a correct statement. the inlets and outlets for the fluid transfer to the blower will not line up, and the radiator impedes the function of the blower. you will have to have a shop custom make and mount one for you.
2) there are certain little things, such as custom radiator lines that will need to be made.
3) the ECU requires a reprogram. The problem is there is no actual program made for the 3.0 accord with a blower. Therefore you will have to have a machine shop program and tune it for you. if not, you can get what is known as a piggyback system, or seperate engine managment control system.
so a blower can be put on your car, but it will take planning, and most important money. the kit is close to 5 g's from comptech, although they said they may cut down a 400 discount because they would not do the ECU program
Old Jul 25, 2007 | 11:03 AM
smaglik's Avatar
this sounds pretty in deptth....keep us informed if you decide to go that route...
Old Jul 25, 2007 | 08:32 PM
stevent's Avatar
you can find alot of info about supercharged cars at v6p.net since there are some members over there that have taken that route.
Old Jul 25, 2007 | 09:11 PM
Should you decide to go that route, keep a log on your process and then we can post it as a FAQ when it's all done with.
SPBAV6
Mar 3, 2015 04:51 AM
jdmjnky
Aug 20, 2010 08:25 PM
doop
Aug 24, 2009 12:03 AM
Yorty
Aug 2, 2008 09:13 PM
Vialas
Mar 20, 2008 08:40 AM
