2003 4CYL Turbo?
Old Mar 22, 2006 | 11:41 PM
marbro's Avatar
Default RE: 2003 4CYL Turbo?
Be a little more specific on this one, Running no2 will fuse everything together. Its basically like dropping napalm in your engine. Its an extremely high temp burst that happens. And you should learn to redrive in consideration of it because of the damage that can be caused if something goes wrong.
Old Mar 23, 2006 | 07:30 AM
lightshow's Avatar
and no2 is an oxidizer. so it eats metal
Old Mar 23, 2006 | 10:43 AM
RTexasF's Avatar
Super Member
Sounds like it's not the thing for longevity!!!!
Wet shot is preferred and more expensive, is it easier on the engine due to added fuel and cooler plugs?
On the other hand a custom turbo or Whipplecharger would be incredible but they are way beyond my means.
Old Mar 24, 2006 | 02:16 AM
marbro's Avatar
Well, wet shot usually uses a direct port on the intake manifold, which gives 100hp I think the lowest might be 75ish hp on a wetshot. So any way you look at it, its not much easier on the engine. But a westshot = new rods and forged pistons. Otherwise you will end up destorying the stock pistons.
I personally believe a turbo is the only way to go. Or if you can afford more then double the premade kit cost, supercharge
but...... whipple charger?
Old Mar 24, 2006 | 05:09 AM
lightshow's Avatar
hahha yea whipple. i love those chargers. kenne bell too....
there are centrifigal chargers like powerdyne or vortech
and then there are roots or screw type chargers like whipple or kenne bell or like a 8-71 lysholm .
Old Jun 16, 2006 | 11:13 AM
03Sleeper's Avatar
Is there a cheaper alternative to get a bigger bang under the hood?
Old Jun 16, 2006 | 07:51 PM
  #17
marbro's Avatar
the cheapest thing you will find is nos
cortzeigler
Jul 30, 2012 01:58 PM
CASCIO
Apr 29, 2009 07:06 AM
JkillaAcc02
Apr 23, 2008 01:15 PM
streetcustoms
Nov 1, 2007 11:31 AM
Accordn2dis
Sep 5, 2006 11:40 PM
