Buying this info needed...
Old Mar 1, 2007 | 02:06 AM
BLuEPiTBuLLz's Avatar
Default Buying this info needed...
http://cgi.ebay.com/ebaymotors/Tread...84522324QQrdZ1
Hello all,
I plan on buying this within the month and want some positive/negative feedback if possible... My first question is... Is there a diffrence between auto/manual kits because my car is an automatic 2 door 97 SE F22b2... I know I will need to upgrade the fuel system with a new higher volume pump and injectors... other then that the only thing i can think of that it doesnt include is a boost gauge... i plan on buying the boost gauge and 2 other gauges (want a 3 gauge pod on my pillar) what other gauges would u suggest or recommend? Fuel Pressure??? Trans temp??? Also would u recommend an auto trans cooler for this if im only planning on running low Psi...5-8... I will be doing the install myself in my garage so any helpful inputs and links to items i will be needing to include in this build would be greatly appreciated... also i heard i need the missing link for the map <~~~ not too smart on computers so i will be needing a link and maybe small description of exactly what this is and looks like... Sry if this sounds kinda noob... but i need POWER... Thx alot for any help!
Patrick
Old Mar 1, 2007 | 04:27 PM
HondaRacer4Vtec's Avatar
Default RE: Buying this info needed...
That kit looks great, yeah since you have automatic, i highly recomanded getting tranny cooler even though your boosting small. From what i hear you need the missing link in order for you ecu to read past 1bar. it only like 50 bucks ill give ya a link.
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
ON instrcutions i wish i cold help you there, i myself am looking on instrctuions i havent been able to fins some..
Old Mar 2, 2007 | 07:12 PM
Where does that missing link hook up? Sry if that sounds like a newb question...
Old Mar 4, 2007 | 12:43 AM
marbro's Avatar
on top of the trottle body is the map sensor, it goes there, all that it does it create a bypass for the extra pressure that the map isnt able to read, unless you plan on redoing your ecu to allow for a 2 or 3 bar map its a temporary fix, but if you dont plan on redoing your ecu, you need it.
paul 141
Dec 5, 2010 02:31 PM
chakwalian
Jul 6, 2009 09:44 AM
Rogizzy123
Mar 29, 2008 01:28 PM
HondaAccordFan
Sep 11, 2007 04:57 PM
crazielude
May 7, 2006 04:40 PM
