Does Anyone In The Forums Run Nitrous???
Old Jan 22, 2006 | 07:15 PM
  #21
fatboys94
Default RE: Does Anyone In The Forums Run Nitrous???
if you are scared of running nitrous then get used to seeing tail lights alot so i wouldn't be scared of nitrous because i run a 105 shot though a stock motor (f22b2)
Old Apr 19, 2006 | 01:23 AM
  #22
tunafisher88
this is just a pet peeve of mine, but i think it should be called nitrous, not nos, nos sounds rice, and rice is bad, but im for and againest nitrous because it would be fun as hell if you had it hooked up to zip around in but if it isnt hooked up right, you blow your engine in like a millisecond
Old Apr 19, 2006 | 01:29 AM
  #23
marbro's Avatar
had a friend who ran no2 on his grandam with only a 60 shot, he has everything hooked up right. Didnt change the fact that he destroyed some of his intake valves. And running direct port wet on a stock engine without even upgrading the connecting rods or the pistons to forged will bring you some happy misfortune.
Has nothing to do with being scared, it has to do with the eventuality of ruining your engine.
Turbo > no2
Old Jun 5, 2006 | 07:02 AM
  #24
zexaccord02
I have a 2002 accord SE 4 door sedan with a 55 shot ZEX dry kit on it. It works perfect for when i need it. i have headers and intake and a dual exaust on my 4cyl. i mean its a cheap way to go fast but it dont last long for nothing. but i use it anytime. mine activates by the trottle positioning sensor and an arming switch. used it off the line but mainly on a role. i have also done it from 40 all the way to 120 just kept it floored racing my friends v6 altima spanked it too. i was very sceptic at first but got it only for a car show i entered to purge but then i had to try it. i've had it in for about 3 months and used about 10 tank fulls already in a 10lb bottle and nothin wrong or has blow up. i have family members that drag with nitrous and also a good friend that installed and fills my bottle that installs performace parts for a shop for a living tell me if i use it right and dont put any more than the 55 shot that i have nothin should happen. he says that 55 shot for an f23a1 stock motor is good nothing more. and with my little mods it would handle fine. i would rather prefer a turbo kit but i havent seen a resonable kit yet for it, but if i keep it i plan of turboing it. its cheap hp and its fun will it lasts so as long as you use it and dont put to much shots in then you should be fine.
Jul 29, 2013 12:55 PM
Robert 1991
Mar 30, 2012 04:13 PM
Super Eurobeat
May 7, 2008 10:53 AM
terrypm
Sep 19, 2007 10:43 PM
