getting the f23 turbo ready
Old Oct 15, 2007 | 04:39 PM
falkore24's Avatar
Default RE: getting the f23 turbo ready
ORIGINAL: sir_nasty
Bosch plugs run a different resistance than NGK's, it's enough of a difference that it can cause your coil to overheat and burnout. I've personally seen it happen more than once to the same car and heard of it happening a few times on here.
Your '92 may have had a different type of coil than the more recent ones. Also, with your current setup, I'd expect a stand alone ignition.
Old Oct 15, 2007 | 07:17 PM
MrGmo's Avatar
should i get NGK iridium? im going to change them out tonight. lol
Old Oct 16, 2007 | 10:06 AM
falkore24's Avatar
Iridiums are good, but if you plan to use a capacitive discharge ignition, the small point electrodes will get fried off. Other than that, NGK Iridiums are a great plug. For an MSD ignition or similar, I'd look at Champion, ZEX, or NGK platinum. Platinum is no good for nitrous though.
Old Oct 16, 2007 | 01:31 PM
Shadow1992's Avatar
I do have the stand-alone. Also my old engine was the "performance" F22A6 for the 90-93 models, so it had a larger external coil vs. the standard internal coil.
Old Oct 17, 2007 | 07:47 PM
MrGmo's Avatar
can i get the denso iridium ones?
Old Oct 17, 2007 | 07:57 PM
MrGmo's Avatar
btw my ignition system is stock
Old Oct 18, 2007 | 07:35 AM
  #17
falkore24's Avatar
sure .... I have the Denso's! Never had a problem, but as I near 90k I'm going to change to NGK's. A little more expensive and a little better (per ratings anyway, my personal testing shows the same spark).
Old Oct 18, 2007 | 11:41 AM
  #18
MrGmo's Avatar
autozone over here didnt have the densos in stock... only had 1 spark plug LOL....
i picked up the champion autolite double platinum.... and so far.... WAYYYYY BETTER than the bosh i used to have in there.
i noticed WAYYY better performance, faster and smother acceleration, and the shaking while on a high geer at low speeds went away, unless im near like 900rpm on 3rd gear lol (did it just to test it)
only thing is that my MPG is probably going to decrease dramatically.. due to the urge to punch it more often LOL.... i really have to stop that .... haha..
Thanks for the advice on getting the boshes out....
Old Oct 18, 2007 | 11:55 AM
  #19
falkore24's Avatar
LOL .... no problem ..... it's actually everyone else's advice! Especially DH. I'm just the parot here.
jroxz44
Nov 21, 2012 02:11 PM
19Accord97
Sep 14, 2008 05:07 PM
zeus24
Sep 7, 2007 12:29 PM
BlackAngel
Mar 26, 2007 12:07 AM
Zambo
11
Jun 24, 2006 12:17 AM
