nos
Old Sep 11, 2007 | 12:32 PM
  #21
KevinAccord's Avatar
Default RE: nos
im sreading that last post over and over again, but can't find the point of the post....
Old Sep 11, 2007 | 03:23 PM
  #22
accords own's Avatar
Default RE: nos
ORIGINAL: BlkCurrantKord
ORIGINAL: deathcrow
ORIGINAL: 02BlueAccord
Were can i find a good nos system that isnt to exspensive? I have a 02 accord auto tranny 2.3L v-tec F23A1 motor.
U need nos??What for?? Wanna act like FnF movie?U have AT tranny.Nos help low rev...Turbo for high rev.Nos for high rev that could be.U need more n more $ to get that way.
That makes absolutely no sense.
x2...i talked to the shop i go to and they said my fujita cai is perfect for NOS and said i should save up for a set-up. i think i will, but i will look into a turbo, too.
Old Sep 11, 2007 | 08:46 PM
  #23
Default RE: nos
don't combine both!!!!!!! u'll blow up ur engine!!!!! (unless is extremely modified!)
Old Sep 11, 2007 | 09:20 PM
  #24
Default RE: nos
wait you mean to not combine the nos and turbo?or intake and nos?
Old Sep 12, 2007 | 07:45 AM
  #25
BlkCurrantKord's Avatar
Default RE: nos
ORIGINAL: KevinAccord
You can run both and not blow the engine. It'll shorten the life of thestock engine but you can run both.
Old Sep 12, 2007 | 07:59 AM
  #26
falkore24's Avatar
Default RE: nos
He means nitrous and turbo. The reason is that with the boosted charge of air, the pressure just after spark ignition is already high and adding nitrous will increase this a lot more. Without a block guard, forged pistons, forged rods and an upgraded head gasket the combination is dangerous.
Nitrous without turbo will produce similar increases in the instantaneous pressure as the turbo (more or less depending on jetting ... amount of N2O). Wet is safer because it injects gas with the nitrous to prevent over-leaning of the mixture. If the mixture gets too lean, the exhaust will heat up tremendously and melt the seals off of the cat and/or muffler (seen it happen). If you limit to a 50 shot, a dry shot with the Zex filter-charger (or whatever it's called) is the easiest install. For an AT, the best activation is a WOT switch that will activate within an rpm window. If you go the dry/filter-charger route, when you spray, be sure not to drop the throttle too much quickly as I've seen this cause back-firing and over-leaning. This is because there is still nitrous in the intake tube, but the narrow-throttle tells the computer controls that it should lean-out the mixture since you aren't flooring it anymore ..... but the time that the over-lean mixture hits the O2 sensors, it may be too late. This won't happen if you let off the pedal to 95% for a second before you slow down.
Old Sep 12, 2007 | 09:40 PM
  #27
vtecHef's Avatar
Default RE: nos
( in respnose to the AWD question)
Buy a Subaru... lol
Old Sep 13, 2007 | 10:09 AM
  #28
Default RE: nos
thanks for the info Falkore! i probably will just get a tuned turbo if anything. but considering nitrous system.
Old Sep 14, 2007 | 08:18 AM
  #29
falkore24's Avatar
Default RE: nos
On an '06?!? Go for it! You're lucky, you don't have the POS tranny that the 6th gens have ..... also, you have the REAL vtec system. My J30A1 is still looking for the second vtec stage (because it's not there until '04)
Green_Accord
DIY Answers.
May 4, 2012 02:44 PM
Tarsis
May 2, 2006 06:13 PM
Green_Accord
May 1, 2006 04:03 AM
Green_Accord
May 1, 2006 02:18 AM
Chadd122
Jan 16, 2006 01:09 PM
