Is It possible to run 13-15 psi on a f23a4?
Old Jan 9, 2009 | 07:52 PM
BlkCurrantKord's Avatar
Default RE: Is It possible to run 13-15 psi on a f23a4?
ORIGINAL: falkore24
Really?!? .... the bearings on the tC start to have issues around 350 bHP and my car-s limit is at 6300.
Rly.
Well, what are the rod/main bearing sizes on the TC's engine?It must have a really poor R/S ratio.
6300rpm redline? WTF?!
G23 = F series SOHC block + H series DOHC (Vtec or Non) head.
Old Jan 9, 2009 | 07:55 PM
ORIGINAL: BlkCurrantKord
ORIGINAL: falkore24
Rly.
6300 rpm redline, WTF?! Well, what are the rod/main bearing sizes on the TC's engine?It must have a really poor R/S ratio.
The K-series can take more than 9-10 psi, but they also have higher compression than our motors, so thats a lot of air/fuel and heat to squeeze into a combustion chamber.
Old Jan 13, 2009 | 04:58 PM
KevinAccord's Avatar
ORIGINAL: blackadept
Thinking about building a f23 because.....well nobody does.......
wrong... i did... and it's a charm... it's not the fastest thing in the world but it's pretty unique...
Old Jan 13, 2009 | 05:02 PM
i've been runnin 7psi on stock internals for more than a year and a half... so far so good... opened the engine 2 weeks ago and it looks neat...
Old Jan 14, 2009 | 12:15 PM
falkore24's Avatar
ORIGINAL: falkore24
Rly.
I'll have to look it up ..... gonna have to get back to you on that one .... too busy right now.
Old Jan 21, 2009 | 06:19 PM
Omegastorm99's Avatar
The G22 or G23 is a freaking awesome swap the sleeves in the sohc block are Iron so when doing the build all you need is forged piston and rods. no need to change the crank unless cracked or something. The H22 head has DOHC and far more options as far as cams, gears, and valve train and also intake manifolds too. you have to use the the F23 head gasket, plug two of the drain holes on the head with like JB Weld. and then you need the H22 water pumpgears and internals and install them in the F22 water pump housing put it all together and get it tuned properly and you are off and running
yiannix
Nov 2, 2008 11:09 PM
rob3201
Mar 15, 2008 12:11 AM
rob3201
Dec 26, 2007 11:34 AM
2002haccord
35
Sep 8, 2007 02:32 PM
KevinAccord
May 16, 2007 02:58 PM
