Should i buy?
Old Aug 4, 2006 | 12:56 AM
mbo1985's Avatar
Default RE: Should i buy?
That is a decent wastegate... like marbro said, that's what I have been using the whole time. Not one problem. hit max boost and it just stays there, no surge or flux.
If it comes with a 15 psi spring (mine did!) you WILL need to change that. Your car will run like crap when you floor it since you will most likely max your fuel system out and the motor will get funky...
It will be a tight fit. I had to trim the shrouding on the radiator fans, and remove the washer fluid tank (I replaced it with a tiny container, plus trim the sheet metal where the washer neck came through, etc. But it will fit. And with room to spare.
Old Aug 4, 2006 | 01:09 AM
ncsgoofy's Avatar
ORIGINAL: mbo1985
Can i just pick up another of Ebay or where ever, like a 8 psi.
Where did you get youre downpipe? I cant seem to find one.
Ok so i NEED to buy the kit, manifold, downpipe, screws, anything else. Whats this FMU ive been reading about?
Old Aug 4, 2006 | 01:29 AM
ncsgoofy's Avatar
http://cgi.ebay.com/ebaymotors/OBX-T...QQcmdZViewItem
OBX is good right? Will this work good?
http://cgi.ebay.com/ebaymotors/Honda...QQcmdZViewItem
why does this one look so funny?
Old Aug 4, 2006 | 02:26 AM
OBX products have been in some of my cars for 5 years already, they make many good engine parts + other good units for other parts of your ride..plus they are made well and look like good quality...
WheelbrokerAng [sm=americanasmiley.gif]
Old Aug 4, 2006 | 10:39 AM
marbro's Avatar
its the difference of design, but the second is refered to as a log style manifold, The one i have is similar to that but mine is one specifically from the drag turbo kit, and depending on which one you get will depend on the downpipe that you get. the obx one by design is more effecient because it channels the exhaust gases to the turbine of the turbo vs the log style which just lets the gases turbulently flow to the turbine which means its not flowing as fast as it could, but the log style takes up less space in the end, thats basically the trade off might be the difference of 100rpm spool time? not sure on that tho
Old Aug 4, 2006 | 02:02 PM
ncsgoofy's Avatar
Ok so i'll buy the OBX soon, where can i find a downpipe?
I just bought a oil feed kit, 8 psi WG spring, and a synapse MAP thingy. Im so excited. So all i have left is the kit, manifold, downpipe. Anything else i need. I dont know much about turbos but i learn fast.
Old Aug 4, 2006 | 08:21 PM
  #17
mbo1985's Avatar
You can either purchase a down pipe from a drag turbo kit, or keep your eye open for one on ebay or you could buy some pipe and fabricate one yourself. And the last option would be to leave it to an exhaust shop.
I found a used down pipe on ebay (I checked every day till I found one) and modified it for my application. This is the hardest piece to find, but it isn't hard to make one.
Old Aug 5, 2006 | 12:24 AM
  #18
ncsgoofy's Avatar
Will another downpipe work? like from a H22 or something? I know i good exhaust place close to me, but would rather not spent the money.
Old Aug 5, 2006 | 01:03 AM
  #19
mbo1985's Avatar
The H one would probably work, but you'll probably have to rotate the flanges and re-weld them. Hopefully you won't (I had to), but you will if the flange doesn't line up with turbo 100%
Old Aug 5, 2006 | 01:17 AM
  #20
ncsgoofy's Avatar
http://cgi.ebay.com/ebaymotors/T70-T...QQcmdZViewItem
How about this the cut off the top and weld backwards?
