STS turbo kit
Old Mar 8, 2007 | 04:47 PM
trukid21's Avatar
Default STS turbo kit
has anyone have seen the new STS turbo kit that is bolted on where your muffler used to be? i saw this show (powerblock) that they installed one on a 06 corvette Z06 and i wondered if they could install those on accords too?
Old Mar 9, 2007 | 09:25 PM
marbro's Avatar
Default RE: STS turbo kit
dont know where you saw that but if you think you can put a turbo anywhere else other then next to the engine exaust manifold and have it be effective.... more power too you
Old Mar 11, 2007 | 12:33 PM
trukid21's Avatar
i checked theSTS turbowebsite, apparently it isonly being installed on american big block cars like corvette,mustangs, and firebirds,etc. I guess it would be a matter of time that it will come around to hondas. oh well. If you have time mabro, check it out and see how cool that setup is.
Old Mar 11, 2007 | 02:16 PM
marbro's Avatar
oh trust me, ive seen pictures 1100hp vette and they made it look like the whole system was suppose to be in the car. But in the end, turbowise, i wouldnt worry about name brand kits, it wont be cheap in the end and it wont really change how it should be installed or what needs to be installed ^_^
Old Mar 11, 2007 | 07:21 PM
trukid21's Avatar
yeah i know, i just thought it look cool. besides that set up cost about $5000 and no way i could get something like that. i'll just stay grounded. thanks for your input
Old Apr 20, 2007 | 02:43 AM
theBrewMeister's Avatar
In theory, this wouldnt work because air is highly compressable. So, after 10 feet of piping your losing a lot of pressure. If you dont believe me, go blow thru a 2ft section of garden hose and feel the air coming through. then go blow through a 10ft section and i bet you wontfeel muchif not anything.Its strange that they are able to makethis work. However, I bet its still very inefficient.
Old Apr 20, 2007 | 03:47 PM
Shadow1992's Avatar
YOu can make it work but it's limited in it's potential. The only plus side to it is you eliminate the heat concerns of having the turbo in the engine bay. So you can go with little or no intercooling with it. The downside is like theBrewMeister said, you lose a lot of pressure, both in the compressed intake charge going back to the engine and exhaust pressure from the engine. So you could never run the system at really high boost levels.
cortzeigler
Jul 30, 2012 01:58 PM
streetcustoms
Nov 1, 2007 11:31 AM
lightshow
Feb 19, 2007 07:07 PM
Accordn2dis
Sep 5, 2006 11:40 PM
no_doz
Jun 17, 2006 11:28 AM
