Turbo build
Old May 25, 2009 | 10:44 PM
liam71234's Avatar
Default Turbo build
I'm looking at doing a turbo build. I'm trying to decide on what turbo will work on my accord. It's just a stock f22. Would a Garrett T3/T4E Turbo, 50 trim compressor, quick spooling stage II wheel with a 5 bolt .48 A/R discharge be a good size for an f22? I'm considering this one because I know someone selling one that he never ended up using for about half of retail.
Old May 25, 2009 | 11:31 PM
liam71234's Avatar
I just updated my signature so you guys know what i'm working with now. I can actually get this kit from a buddy that he pieced together everything's brand new. Is 1800 a good deal.
Garrett T3/T4E Turbo, 50 trim compressor, quick spooling stage II wheel with a 5 bolt .48 A/R discharge. Good for up to -400+HP. Turbo comes with internal wastegate (7psi).
-Includes gaskets for turbo an oil lines
-GReddy Intercooler kit (Type 24V) - comes with couplers and clamps (supports up to 700hp).
-Boost tube (Upper Intercooler pipe) w/flange for HKS SSQ Bov.
-Braided stainless steel oil feed and return lines/hardware.
-HKS Super Sequential Blow Off valve.
-2.5" downpipe (will allow you to keep a/c) with 5 bolt exhaust flange.
-GReddy Turbo Timer.
-ProSport 52mm Boost Gauge (illuminates in amber or white) w/single gauge pod (for '97-'01 Prelude).
Old May 25, 2009 | 11:54 PM
liam71234's Avatar
I'm going to go with an aem adjustable fuel pressure regulator and a walbro fuel pump for fuel management.I have a cast iron turbo manifold already. I've been looking at engine management is there anything cheaper than an aem plug and play kit for engine management? also what injectors should i use?
Old Jun 2, 2009 | 08:04 PM
falkore24's Avatar
Originally Posted by liam71234
-Garrett T3/T4E Turbo
-internal wastegate (7psi).
-2.5" downpipe
-single gauge pod (for '97-'01 Prelude).
ITEMS MISSING FROM YOUR LISTS
-Cold Pipe and filter (MAF mount if your car needs it)
-Wideband O2
-Oil Pressure Gauge
-3 gauge pod
-external wastegate
-dump tube or recirc
Injectors are easy. There is a calculator online. You're kinda lucky, my car can't use the simple computer's that work on Hondas. The OEM computer teaches itself to 'fix' what the piggyback does, but my AEM FIC and 550 injectors will teach it!!!
Old Jun 11, 2009 | 08:50 AM
KevinAccord's Avatar
how your tc coming up falk?
Old Jun 28, 2009 | 02:51 PM
omiban
Default Turbo build
The staggering demand for mobile Internet access and connectivity for a range of Web-enabled devices creates numerous opportunities for operators and OEMs (and drives the innovation that keeps consumers satisfied), but fully realizing the opportunities requires innovative solutions.
As the demand is met, more competition for limited bandwidth resources grows. Building on the strength of Opera Mini data compression technology, the Opera Turbo browser was developed to help optimize these resources.
Operators, OEMs and consumers all reap the benefits of Opera Turbo's data compression and savings technology.
Operators can:
Reduce network traffic and save on data transmissions
Improve the Internet experience by increasing Web page download speeds and performance
Extend the longevity of mobile network investments
Stay ahead of the competition by deploying quickly
Increase user satisfaction and retention
Control or restrict certain content
Gain insights into consumer behavior
OEMs can:
Improve the Internet experience by increasing Web-page download speeds and performance
Maximize hardware capabilities by processing server-side
Achieve and maintain time to market
Enhance usability/user satisfaction
Deploy across platforms and chipsets and with both low- and high-end hardware
Enable a full browsing experience on low-end hardware by reducing memory and CPU usage
Consumers enjoy:
Improved Internet experience with browser speed and performance
Greater affordability and cost predictability
Optimized browsing experiences on low-end device hardware
A consistent, stable, high quality Internet experience across a variety of products
cojac82
Apr 25, 2010 08:49 AM
importnewbie
Aug 16, 2007 05:11 PM
94coupeaccord
Jun 4, 2007 07:50 AM
03Sleeper
May 10, 2007 09:38 PM
Accordn2dis
Sep 5, 2006 11:40 PM
