Turboing a 1994 acoord
Old Jul 19, 2008 | 02:17 PM
sUbLiMe96's Avatar
Default RE: Turboing a 1994 acoord
Well, thanks, but just keep in mind, the Apexi AVCR controls how much boost you want from 5psi-up
Old Jul 19, 2008 | 03:17 PM
clutch811's Avatar
oh sorry kinda of misread. actually thatd be perfect but another problem for me is the $$$. got to get some routine maintenance done and save some cash and learn a little more and then maybe next summer or so. if you still got it then ill definitely consider.
Old Jul 21, 2008 | 01:06 PM
KevinAccord's Avatar
why do you need an AC bypass belt? H20 pump? are you removing your a/c?
Old Jul 21, 2008 | 01:47 PM
clutch811's Avatar
A/C coming off. its a dead stick not even worth recharging and too much to replace plus im a power junkie and 4 60 air is all i need. the car is due for a new timing belt and water pump.
Old Jul 22, 2008 | 10:15 AM
oh, ok... Long time i don't hear the 4 win down and 60mph A/C! LOL!
Old Jul 25, 2008 | 11:45 PM
clutch811's Avatar
haha. yeah its my favorite thing to tell people and theyre like. wtf is that. lol question: so as im seeing through sublime when it comes to turbos and boost controllers how does that work? how do you pick the turbo and what does the controller do?
Old Jul 28, 2008 | 06:26 AM
  #17
you just pick the right size for your car. which means that it would be one with a smaller exhaust 'snail' (as we call it here) and a bigger intake 'snail'. A t3/t4 hybrid bb (ball bearing)will be great for you. A boost controller just let's you adjust the amount of boost you want your car to produce.
Old Jul 28, 2008 | 06:29 AM
  #18
remember that the spring on your wastegate will also determine the amount of minimum boost you can have. so if you have a 7psi spring, don't expect lower psi than that. A boost controller is good, but just don't put it inside your car. know why? cause you will race someone and they will beat you, and next thing you know you will want to add +5 psi to beat him and gonna break your engine... IMO it's better under the hood.
EDIT: Im not post whoring, is that I can't write much because it gets erased...
Old Jul 28, 2008 | 04:58 PM
  #19
ford's Avatar
unless he has self control, then he can still put the controller inside...lol!!!..OR his engine can tolerate high boost..then he can too=))=P
Old Jul 28, 2008 | 05:19 PM
  #20
clutch811's Avatar
hmm. interesting something for me to look into. well i just got my car done today and im impresssed it runs stronger and quieter. also my compression test came back as 205,200,195, and 205. hows that
