what turbo kit should i get
Old Jan 11, 2011 | 02:57 PM
X I KUTE's Avatar
Default what turbo kit should i get
I have a 1995 accord ex vtec 5 speed, i would like to get a turbo to run 10 psi max, what do you think i should get?
im open to any suggestions
thanks!!!
Old Jan 11, 2011 | 03:43 PM
ebarrera661's Avatar
Almost A Senior Member
G22 (Moderator) will be in here shortly..
Old Jan 11, 2011 | 07:51 PM
g22cd5's Avatar
Supper Moderator
stock engine?
edit - what is your power goal and price range?
Old Jan 11, 2011 | 09:30 PM
clutch811's Avatar
I believe theres only one company that makes a kit for our cars anymore. Forget the name though. Honestly I would do the research and piece together your own kit. added to what g22 asked. how many miles are on your motor/car?
Old Feb 2, 2011 | 07:37 PM
corvetteking's Avatar
I love it when people say I wanna run X amount of boost... People need to learn that it does not matter how much boost you run, as much as what size turbo to run, what kit you would like... There are several manufacturers that make turbo kits for these accords... You will need to invest in a good ems, and get a good tune, as this will have the biggest issue with adding a turbo kit to your car...
Old Feb 27, 2011 | 02:37 AM
davidg99's Avatar
Default Boost does actually matter!
Knowing how much boost you want to run will help in determining what kind of turbo, BOV, wastegate and all that good stuff that you will need. Boost = Hp! The higher the boost the more HP you will make. I do agree on researching the subject so that you can put your own kit together.
Old Mar 3, 2011 | 01:04 PM
abelart's Avatar
Honda Turbo kits like accord turbo kits, CRX Turbo kits, FIT Turbo kits, Prelude Turbo kits.
Old Mar 5, 2011 | 01:43 AM
g22cd5's Avatar
Supper Moderator
Knowing how much boost you want to run doesn’t help at all with how much power your going to make.
One turbo pushing 20psi can be equivalent to a bigger turbo pushing 12-13lbs.
As vettking said it's all about knowledge in what size turbo you want NOT how much psi you want to run.
Hector215
16
Jul 24, 2013 06:53 PM
Hector215
Apr 7, 2013 02:52 AM
Sep 19, 2010 07:11 PM
twch04
24
Jul 16, 2008 09:49 PM
j_man_honda
Feb 18, 2007 09:54 PM
