5 spd h23
Old Dec 10, 2008 | 07:39 AM
  #41
falkore24's Avatar
Default RE: 5 spd h23
ORIGINAL: live2rice
Well I race at the track, so I have to have a NHRA approved battery box and killswitch.
There is a timing belt cover on the H22, it does have cut outs for the cam gears however though.
Actually it appears only some have the cut outs for the cam gears, my new one does, but old one doesnt.
Do you need a box if you have a sealed, closed-cell gel type battery??? I'm relocating my battery as part of the system install and big 3 upgrade. Having the batery in the front corner is the worst place for it as far as handling goes. It needs to be behind the front axle at least. I may use a cheaper brand, but check out the Braile batteries.
Old Dec 10, 2008 | 07:41 AM
  #42
I think so, because i dont think they want to have to look into what kind of battery you have. And a battery box doesnt weight that much anyways. Debating going with like a 8lb CF battery.
Old Dec 10, 2008 | 08:34 AM
  #43
falkore24's Avatar
what brands are you looking at? CF seems dangerous for the shell of a battery ..... I'd feel much more comfortable with an ABS shell.
Old Dec 10, 2008 | 08:54 AM
  #44
I was looking at Braille batterys. CF is available in 6.6lb and 11.5lb. They also have what i assume to be abs in 6.6lb and 9lb.
do you think 6.6lb is too small and would be required to be charged at night or whatever?
Old Dec 10, 2008 | 09:00 AM
  #45
falkore24's Avatar
For your racecar, I'd have someone start it after letting it sit for a day or more, on a really cold night while you watch an ammeter under the hood. Then, double the amperage and see if the tiny batteries can do it. Obviously I'm adding a large safety factor, but I think that it's a good benchmark, especially considering the lab conditions that the tests are done under never really indicate actual performance.
Old Dec 10, 2008 | 09:04 AM
  #46
Yeah I mean it will never be used in the cold, and wont be daily driven, just would like to be able to drive it to a friend house, hang out for a couple hours, and know it will start when I go to leave.
Voltage: [?][/align] 12 Volts
[/align] [/align] Full Charge Voltage:[/align] 13.8 Volts
[/align] [/align] Short Circuit Current (Max Cranking Amps):[/align] 760 est.
[/align] [/align] Pulse Cranking Amps (PCA) 5 sec @ 80F: [?][/align] 527
[/align] [/align] Pulse Cranking Amps (PCA) 10 sec @ 80F:[/align] 461
[/align] [/align] Pulse Cranking Amps 20 sec @ 80F:[/align] 407
[/align] [/align] Cranking Amps 30 sec @ 80F:[/align] 314
[/align] [/align] Cranking Amps 30 sec @ 32F:[/align] 283
[/align] [/align] Cold Cranking Amps 30 sec @ 0F: [?][/align] 210
[/align] [/align] Reserve Capacity: [?]
[/align] Less than 20 minutes
[/align] [/align] Capacity (C/20 rate): [?][/align] 10 amp hr
[/align] [/align] Internal Resistance:[/align] 15.8 milliohms (.0158 ohms)
[/align] [/align] Life Cycle @ 10% DOD: [?][/align] 3000 cycles est.
I'm sure that means a whole lot more to you than it does to me.
[/align] [/align]
Old Dec 10, 2008 | 04:13 PM
  #47
falkore24's Avatar
Looks pretty good, but first I'd still see what your car pulls when cold on a cold night .... also, record the test temperature for comparison.
Old Dec 10, 2008 | 04:58 PM
  #48
yeah my car doesn't "pull" anymore lol
Old Dec 10, 2008 | 06:39 PM
  #49
falkore24's Avatar
try the test on your other car
pinecone
Aug 2, 2009 09:47 AM
kriegz99
May 7, 2009 08:29 PM
storms
Nov 29, 2007 06:59 PM
tradosaurus
Apr 26, 2007 12:18 PM
tradosaurus
Apr 22, 2007 04:53 PM
