cleaning an engine
Old Jan 22, 2007 | 10:28 PM
Honda_Dude's Avatar
Default cleaning an engine
i want to clean my engine but i dont kno if i should use a decreaser or any other kind of cleaner or just spray the engine with water? am i suppose to cover things like wires, intake or anything else before starting? what is the safest, effective and easiest way to do it.......all comments are welcoome. Thanks!
-Kev
Old Jan 23, 2007 | 12:21 AM
hondadude's Avatar
Default RE: cleaning an engine
Just take your garden hose and spray away
CHUMP
Old Jan 28, 2007 | 06:16 PM
adamc44's Avatar
when i was detailing i would let the engine run for about 10 minutes to get good and hot. then, with the car running,i would get some degreaser and spray it down, you will probably want to stay away from the spark plug holes if possible, and throw a plastic bag over the distributor. then i would use a water hose and spray the engine off. after i was done, i would let the car run for an additional 10 to 20 minutes till everything was pretty well dry. i would shut her off and spray some sort of chemical that made plastic shine up. i cant remeber the name of it though. after that i would wash the car really well,cause there was always degreaser on the paint. hope this helps. adam
Old Jan 28, 2007 | 09:18 PM
deserthonda's Avatar
I would not advice cleaning the engine,,( spraying it ) while engine is running,,
YO Honda_Dude junior ..( since there was 1 already )
with engine off, spary some degreaser in the engine, then get a water hose and rinse it all off
I have done thousands of cars this way and have never had a problem,, ( depending on year and model i would adevice to cover the distributor ),Once all rinsed off, pull the plug wires off make sure no water got in the holes especially if they are non-honda plug wires ,
dorkiedoode
Sep 9, 2007 11:36 PM
fireballer44
Feb 11, 2007 01:40 AM
thunder_x
Oct 8, 2006 06:20 PM
emaxxman
Mar 18, 2006 08:04 AM
HondaPitStop01
Mar 5, 2006 03:17 PM
