DIY Clutch and/or Flywheel Replacement
Old May 22, 2008 | 04:38 PM
finch13's Avatar
Default RE: DIY Clutch and/or Flywheel Replacement
Well, the install is done. Everything works flawlessly. I didn't have my camera, nor was my Grandpa in the mood after 2 days of working on a cramped Honda for me to be taking pictures. I have a few from my cell phone and I'll go out and take pics of what I can.
This clutch/flywheel combo is AMAZING!
Old May 22, 2008 | 04:48 PM
falkore24's Avatar
Awesome!!!
Old Jun 29, 2009 | 11:34 AM
raj49
I know this is an old post. Hope somebody replys.
Did you have to remove the center crossbeam to lower the trans? Is it removeable?
Thanks in advance.
Old Jun 29, 2009 | 01:40 PM
finch13's Avatar
Yes, you need to drop the subframe to lower the trans. You have to outline it with a white marker and just remove the bolts and it drops right down.
Old Jun 29, 2009 | 08:24 PM
raj49
isnt there a motor mount on the front and back? What about the radiator? Does the motor have to be supported at any point?
Old Jul 17, 2012 | 08:17 AM
adampacheco's Avatar
if you take of the serp belt and remove the 2 bolts holding your compressor to your engine you wont evacuate your system. just leave your comressor in the car and rip the engine out.
also in your first reply you talked about chatter. its not because the flywheel is lighter, flywheels are balanced out of the factory with the crankshaft attached, its all together when they balance it. so changing the flywheel means the crank is no longer balanced properly. if you want performance take the crank out the bottom of the engine bolt the flywheel to it and send it to an engine shop to balance the thing.
Originally Posted by finch13
This is the way AllData says to do it, so were going to try this way first and I'll be sure to write down any snags or what would work instead. And engine lift would probably be a lot easier, but we don't have one.
Old Oct 11, 2012 | 06:50 PM
  #17
2Kaccord's Avatar
good stuff! is there a similar one to an 05?
sartoriusrock
Jul 26, 2015 10:16 PM
jwelby
Jan 6, 2014 10:19 AM
Peacemaker98LX
Jan 15, 2011 09:05 AM
Willb2305
Feb 16, 2010 01:08 AM
legionofone
Apr 5, 2008 10:39 AM
