Double clutch
Old Feb 23, 2007 | 12:35 PM
00AccordLX5spd's Avatar
Registered User
Default Double clutch
Does anyone here double clutch when they downshift? Is it actually better for the carif youdouble clutch? Or is it worse?
Old Feb 23, 2007 | 02:16 PM
millpond's Avatar
Default RE: Double clutch
ORIGINAL: 00AccordLX5spd
It's better for the car when done properly, especially when going from 2nd to 1st. It's not necessary in most cases.
Old Feb 23, 2007 | 02:26 PM
sir_nasty's Avatar
I used to do it but the only real reason for it is to match your RPM's to the engine speed so it's smoother and less wear on the clutch, if you downshift at the right time you can accomplish the same thing without double clutching, it's most usefull when you want to drop down a gear into the power band and have it grab it smoothly.... if done improperly though it can be a little bit harder on the clutch...
Homeys1978
Sep 7, 2007 11:33 AM
Eclips3
Dec 28, 2006 03:10 AM
aka22
Dec 13, 2006 06:28 AM
dabflyboy
Oct 10, 2006 01:12 PM
tamb
Jul 21, 2006 01:05 AM
