h22 or f20b
Old Jan 3, 2010 | 10:51 PM
littledrakon's Avatar
Default h22 or f20b
so im deciding to do a swap on my car but in undecided between a f20b or h22a what are your guys thought on wich engine is better since the accord is so heavy
Old Jan 5, 2010 | 11:35 AM
Dale02's Avatar
Back when i was driving a 95 i was debating the same two engines. In the end i would have went for the h22a since finding parts for a f20 would probably end up being up a bitch and there are sooo many for the lude swap
Old Jan 5, 2010 | 04:40 PM
does the f20b offer more hp or both f20b and h22a are the same and are they both direct swaps into the accord?
Old Jan 5, 2010 | 05:02 PM
19Accord97
h22 has more power
However, since you do not have vtec, you more than lkely have the same motor as me, the f22b2. It has iron sleeves unlike the h22 so it can easily handle 6-8 psi of boost.
If your going to swap a motor, go with a k series. It is the new H swap.
Old Jan 5, 2010 | 06:39 PM
was thinking about keeping it single cam and turbo it but i want my car to be runnig low 13s and so idk what would be cheaper keeping it single cam or going h on it and i would do a kseries but dnt have enough funds for that. so what do you thnk f22b2 turbo or h22a swap?
Old Jan 5, 2010 | 10:46 PM
19Accord97
I think low 13s is going to cost you quite a bit of money.
The cheapest route would to just get a $1,000 turbo and call it a day assuming you have the f22b2 which I am almost positive you have if you live in the USA. But a tune would drastically help.
In either case the auto trans will die in no time at all. With the turbo option it would be a more simple install but you DEFINITELY will need the biggest transmission cooler that will fit to prolong the life of the tranny.
DA KID RYU
Feb 16, 2008 04:41 PM
YoungTexasBoi18
Nov 19, 2007 10:13 PM
way2low
Apr 23, 2007 02:45 AM
yosfynest11190
Mar 20, 2007 03:19 AM
VTECPWR
Dec 6, 2006 11:55 PM
