H22 VS F20B
Old Feb 5, 2008 | 09:56 PM
DA KID RYU's Avatar
Default H22 VS F20B
I want to know which engine will do better on a all motor race....
which engine will do better when the compression is down n turbo with 10 psi...
Old Feb 6, 2008 | 07:55 AM
BlkCurrantKord's Avatar
Default RE: H22 VS F20B
ORIGINAL: DA KID RYU
1) I want to know which engine will do better on a all motor race....
2) which engine will do better when the compression is down n turbo with 10 psi...
1) F20B
2)Neither
Old Feb 7, 2008 | 12:48 AM
DA KID RYU's Avatar
so which engine will hold down more..
turbo charged f22b engine or f20b n/a set up
Old Feb 7, 2008 | 08:50 AM
marbro's Avatar
both when you resleeve them
Old Feb 7, 2008 | 10:46 AM
There's too many variables to say which. Obviously you could see way more HP out of the turbocharged motor than out of the N/A motor.
Old Feb 7, 2008 | 09:44 PM
DA KID RYU's Avatar
So if i was to turbo charge my f22b2 engine i would get more hp out of it den if i was to get a f20b engine...
i really like the blue top..
plus its an accords type r engine so it will drop directly with out no problems or new motor mounts. And its sexy knowing u got 200hp out of an engine.Plus the internals are pretty strong.just compression ratio sucks...
how much can u get out a f22 engine with over 20 psi...
an estimate please
Old Feb 7, 2008 | 09:50 PM
400-600whp
Old Feb 7, 2008 | 10:03 PM
DA KID RYU's Avatar
WOW thats pretty nice number thanks blkckord
will da engine handle dat much psi
Old Feb 7, 2008 | 10:04 PM
DA KID RYU's Avatar
willthe engine handlethat much psi
Old Feb 8, 2008 | 05:09 PM
marbro's Avatar
if you build it up to handle that much
