Pressure Washer help
Old Jun 13, 2011 | 11:07 AM
barticus520's Avatar
Exclamation Pressure Washer help
well, I cant beleive it started first off... I have a Karacher 2400psi with a 5hp honda motor(yup happened to be honda.) It was given to me by my dad when he got a new one 4 years ago. Its been sittin in my backyard for the past 3 years n I decided id try n fix it. Turns out it started right up.
I changed the oil, filled with gas(was empty,) n changed the spark plug. Engine runs n starts great but the pump is givin me problems. When im usin it it works perfectly until i stop shooting, when I go to shoot again it has no pressure and I can hear the pump isnt workin. I take the tip off and let the water shoot out(large volume) then put the tip back on and it will work fine till i let go of the trigger again.
Do I need a new pump? or is it something else?
Old Jun 14, 2011 | 07:07 PM
nm, after askin my friend at work(home depot tool rental) he said it was a stuck unloader valve. I googled it and found directions on how to fix it, all i needed was some white lithium grease n it works.
Old Jun 14, 2011 | 08:38 PM
There you go..as I always have said..google it
ChappyBob
Oct 27, 2016 05:44 PM
eduard
May 9, 2013 12:11 AM
56belair
Feb 23, 2013 02:11 AM
de_shadows
Feb 2, 2012 06:57 AM
piconrule
Jul 24, 2009 02:38 PM
