1999 Accord EX I4 rear hub nut size
Old Jun 8, 2009 | 10:46 AM
RTV55's Avatar
Default 1999 Accord EX I4 rear hub nut size
Hello All,
Can anyone tell me what the size is of the rear hub nut on my 1999 Accord EX I4? Changing a rear wheel bearing/hub this evening and want to make sure I have the right size socket. RTV55
Old Jun 8, 2009 | 11:01 AM
finch13's Avatar
Which nut? There are plenty back there... 10mm, 12mm, 14mm, 17mm are all you should really have to worry about.
Old Jun 8, 2009 | 11:37 AM
No the big one on the bearing spindle. Unfortunately I don't remember the size...
I think it's smaller than the 36mm front axle nut, but that doesn't narrow it down much.
Old Jun 8, 2009 | 11:46 AM
finch13's Avatar
Ah...
They won't give me a size...
It is P/N 90305-S30-003, you could call a dealer and ask. My guess is 32mm.
Old Jun 8, 2009 | 12:02 PM
RTV55's Avatar
I'm looking for the measurement of #34 in your diagram. i think it is smaller than the front also. RTV55
Old Jun 8, 2009 | 12:43 PM
finch13's Avatar
When do you need it by? I'm looking at the rear brakes on a 99 sometime this week/weekend, I could give you a definite answer then...
And yes, that part number I posted is for #34, you could call Honda and ask them directly.
Old Jun 8, 2009 | 01:05 PM
RTV55's Avatar
Finch, I'm gonna tear it apart in about 3 hours. I believe the 32mm number you gave me before is correct. The parts guy at my dealer didn't know exactly. I'll just borrow a selection from the mechanics at work here. You're probably getting close to a rear wheel bearing replacement yourself if you're looking at your car. RTV55
Old Jun 8, 2009 | 01:13 PM
finch13's Avatar
Ah, that's a shame I couldn't get it to you faster. I'd bet money that it's an even number and larger than 30mm
Unfortunately, it's a friends car with rear discs (I have drums), but yes, I'm very close to replacing all 4 bearings. I just need to locate a press to use and then I'll rip all four corners apart one weekend. I have a shimmy at highway speed (not sure if it's a bent wheel/unbalanced tire) and the passenger rear has started humming.
Sorry to thread jack, good luck with it!
Old Jun 8, 2009 | 01:18 PM
RTV55's Avatar
It's probably the hummer. That's what one of mine are doing (humming) so it's getting both rears.
Old Jun 8, 2009 | 01:36 PM
RTV55's Avatar
JonJon13926
Jul 13, 2013 11:51 AM
RobinsonRicer
May 9, 2013 01:26 PM
brandon0409
Mar 9, 2012 06:22 AM
nj_accord97
Apr 6, 2009 09:44 PM
dknight211
Nov 10, 2007 10:40 PM
