1999 Accord EX I4 rear hub nut size
Hello All,
Can anyone tell me what the size is of the rear hub nut on my 1999 Accord EX I4? Changing a rear wheel bearing/hub this evening and want to make sure I have the right size socket. RTV55
When do you need it by? I'm looking at the rear brakes on a 99 sometime this week/weekend, I could give you a definite answer then...
And yes, that part number I posted is for #34, you could call Honda and ask them directly.
Finch, I'm gonna tear it apart in about 3 hours. I believe the 32mm number you gave me before is correct. The parts guy at my dealer didn't know exactly. I'll just borrow a selection from the mechanics at work here. You're probably getting close to a rear wheel bearing replacement yourself if you're looking at your car. RTV55
Unfortunately, it's a friends car with rear discs (I have drums), but yes, I'm very close to replacing all 4 bearings. I just need to locate a press to use and then I'll rip all four corners apart one weekend. I have a shimmy at highway speed (not sure if it's a bent wheel/unbalanced tire) and the passenger rear has started humming.
Sorry to thread jack, good luck with it!
