5 lug conversion
Old Apr 2, 2009 | 05:27 PM
jasen klems
Default 5 lug conversion
I was told by a guy at the local hang out that I should be able to use the newer prelude 5 lug set up on my 90 accord coupe. Is that true and if so is it a direct bolt on swap? sorry if this is common knowlage to all of you but this is my first honda. any help would be nice. thanks for all the help....
Old Apr 2, 2009 | 05:44 PM
finch13's Avatar
It's direct bolt on, but kinda pricey. Probably have to use a prelude around 1990 though, not a newer (1997-2001) lude.
Old Apr 2, 2009 | 06:00 PM
cjdm98's Avatar
Brandon are you drunk,No prelude prior to 97 has 5 lugs as an oem option,They are done using 97-01 parts.
To my knowledge,it is a direct bolt on,minus a few hardware pieces and lines,etc.
Old Apr 2, 2009 | 08:05 PM
jasen klems
thanks for the info. I have another questions to put to you all , with a 5 lug lude setup can i run the acura calipers or should i go to the brembo big brake kit?
1990 honda accord coupe
I want to swap a F20B into it
01Accord01
Dec 28, 2014 03:49 PM
joelluv12
Mar 25, 2009 06:44 AM
HORSEPOWERJUNKIE2007
Sep 2, 2008 08:02 PM
jkellyre
May 15, 2007 07:39 PM
Tommy997
Jul 26, 2006 02:14 PM
