5-lug and rear disc swap
Old Jul 30, 2007 | 04:28 PM
BlkCurrantKord's Avatar
Default 5-lug and rear disc swap
OEM Parts Needed -
Front Knuckles L and R
Front V6 calipers L and R
Rear Knuckles L and R
Rear EX (4cyl) or V6 calipers L and R - they're the same
EX 4yl or V6 parking brake lines
OEM or Aftermarket rear disc brake lines - I used Russell SS lines
V6 Accord Rotors/Pads F and R
New Brake Fluid, OEM or Equivalent - I used Valvoline Syntec
Recommended - Change the outer tie rods and lower/upper ball joints if you haven't already. My tie rods were bad (torn) and my D. side lower ball joint was on its way out.
Recommended tools -
4 jack stands
Jack or two
Breaker bar (bigger the better)
17mm, 14mm 6 point sockets - preferably deep
17mm - 14mm wrenches
1/2" and 3/8" ratchets
Assorted extensions for both sized ratchets
Line wrenches (for brake lines)
PB Blaster
Propane torch (stubborn bolts or studs)
BFH - Big F*cking Hammer
Air gun
36mm socket (axle nut)
I haven't finished it yet, just got the fronts done last night and started on the rears today (7-30-07). Probably finish most of it by tonight or tomorrow. Still waiting on a few bolts to come in the mail and figuring out how I'm gonna get the parking brake lines out.
Some teaser pics for now -
Open for business!
The rears
Front D. Side
Lotsa wheels
The carnage
Hit a speed bump in the progress, one bolt on the rear pass side didn't wanna come out. It seized itself in and when I tried breaking it loose with the breaker bar I ended up tearing the rubber bushing loose. I called it quits @ 4 cuz I was just getting more pissed off and frustrated with it. Probably gonna end up cutting it out.
More pics -
Rear D, side out for the most part, just have to remove parking brake.
Front D. Side all put back together, minus brake line.
Front Pass Side - mounted rim just to get an idea of how it would look.
Rear Pass side - Bolt the breaker bar is on
New shift **** on the beater ED, broken baseball bat handle. Its like buttah
[/align]
Old Aug 10, 2007 | 08:51 PM
Default RE: 5-lug and rear disc swap
Made more progress than I thought I would this morning. Parking brakes (e-brake) are done, everything else is bolted up except the rear calipers cuz I don't have any bolts that will fit the holes. So...on with the pics! FYI - these are in reverse order.
Side view...guess you cant really see much.
Rear pass side
Rear D. side
New e-brake cables in
This bolt was a bitch to get out and an even bigger bitch to get back in.
These holes are where the two brackets for the D. side e-brake cable mount, the smaller hole is for a tab on the bracket, the larger is of course for a bolt. These were also a bitch to get back in.
Old e-brake cables, D. side out - that's the back of the carpet showing through that hole. The cables pull right out as soon as you unbolt and unhook them.
Removing old e-brake cables, grab the cable and turn it to the open side (right for Pass, left for Driv) and pull and thats it.
How its all put together once you remove the console, yes I will be cleaning it once I get to it.
Same stuff as above, just a closer shot.
[/align][/align][/align]Aaand..Done[/align]
[/align][/align]
jrzwalker86
Dec 5, 2011 06:49 PM
Andy2k9
May 15, 2010 05:31 PM
sirgilligan
Dec 22, 2008 10:47 PM
BlkCurrantKord
Apr 27, 2008 09:27 PM
KevinAccord
May 21, 2007 01:59 PM
