Brake Setup for 99 Accord????
Old Feb 17, 2007 | 10:12 PM
j_man_honda's Avatar
Default Brake Setup for 99 Accord????
Anybody know of a good brake setup for my 99 accord ex. I would like a big brake kit, but I don't want to spend over 600 dollars. Any suggestions?
Old Feb 21, 2007 | 07:16 PM
samtheturtle
Default RE: Brake Setup for 99 Accord????
This would be almost impossible to do on that budget unless you found some nice calipers at a junkyard from a sports car with 6 piston calipers. Most big brake kits for your model start around $1200.
Your best bet with that cash is to get a larger diameter rotor (drilled and slotted your choice, good looking though) and put on a set of nice brake pads such as metal matrix or those green pads. Make sure if you go for a larger diameter rotor is still fits in your wheel with room for the caliper. The good part about this upgrade is that you can always get the calipers later, but unless you are truly racing this carat 9/10ths or 10/10thsyou will never need better than the upgraded rotors and pads.
Old Feb 21, 2007 | 08:15 PM
sir_nasty's Avatar
I'd agree with sam, just get a nice set of aftermarket pads and some slotted rotors (drilled suck in real race application unless they are porsch or poured that way.....) Brembo rotors, hawk HP pads and some braided steel brake lines will improve matters drastically
DJYoshaBYD
Jan 24, 2008 10:17 PM
theycallmerickjames
Nov 11, 2006 08:19 PM
jimsmith
Jul 17, 2006 10:24 AM
GodMachine
Jun 14, 2006 04:39 PM
nygamble
Apr 26, 2006 05:55 PM
