Chrome Rims - Extra Heavy
Old Dec 18, 2007 | 01:12 PM
Ragbird
Default Chrome Rims - Extra Heavy
Hey, I have chrome 18's on my 99 accord but these joints bang like crazy. I know the wheel is a heavier than the stocks but it sound terrible. Anyone with a fix for my problem. Plus the messed up streets in NY dont help. It sounds like the shocks and struts and bad when i drive, but its all new Tokico shocks and Eibach lowering springs. pls help!!
Old Dec 18, 2007 | 01:20 PM
sir_nasty's Avatar
Default RE: Chrome Rims - Extra Heavy
ORIGINAL: Ragbird
I'm not sure I understand what you are saying.... what's making the noise? What kind of noise is it?
Old Dec 18, 2007 | 01:49 PM
falkore24's Avatar
Tokico's aren't the greatest .... might be bad ..... I haven't theard of heavy rims causing any real problems. It's most likely either the shocks or something broken in the suspension.
Old Dec 18, 2007 | 03:51 PM
JohnL's Avatar
I doubt it's the wheels themselves that are causing a noise or excacerbating an existing one. With 18s you must be running quite low profile tyres which are likely to have quite stiff sidewalls, and I'd suggest this is more likely to be a problem than the rims themselves, that is assuming your noises aren't coming from somewhere else.
Low profile tyres are going to be harsher than the standard set up, you'll probably just have to learn to live with it. They'll be harsher because they are stiffer, they will bang into bumps and potholes with more of a thump, and transmit more of that thump to the wheel and through the suspension into the chassis.
Old Dec 18, 2007 | 03:59 PM
JohnL's Avatar
Or, if I read your post more carefully, the new dampers will transmit more road shocks to the chassis than old worn dampers will, especially if they are also stiffer than standard dampers. Stiffer springs won't help either, but the dampers transmit far more shock to the chassis than the springs ever will. Makes you wonder why people call them 'shock absorbers' doesn't it?!
If you want less road shock then you could try lowering the tyre pressures, but steering and handling will most probably suffer.
Old Dec 18, 2007 | 04:04 PM
sir_nasty's Avatar
your fuel economy would suffer as well... (if you lowered the tire pressure)
Old Dec 20, 2007 | 08:33 AM
JohnL's Avatar
And it's not safe if you go too low, especially on the hwy. You can get excessive heat build up, then tread separation, not nice!
on1accord
Nov 24, 2010 09:01 PM
mak
Apr 24, 2008 01:02 PM
acc0rdman
Nov 7, 2007 09:27 AM
AxCxCxOxRxD
Sep 12, 2007 10:32 PM
elementalJ
Jan 21, 2007 06:32 PM
