coilover installation problem...broken stud
Old Jun 20, 2006 | 04:39 PM
mdlow87
Default coilover installation problem...broken stud
Maybe this isn't really a suspension problem but I need some help guys. I was installing coilovers in my 94 accord the other day. I had just finished the front and was about to install the rear ones, but I couldn't get one of the lug nuts off one of the rims. I tried to use a breaker bar and some muscle but what happened is that I think the stud is loose and the lug nut is still stuck to it so when i try to loosen the lug nut, the stud goes with it. Is there something I can do to fix this problem or do I have to take it to a shop?
Old Jun 20, 2006 | 04:53 PM
sir_nasty's Avatar
Default RE: coilover installation problem...broken stud
have you tried to pull it out? it's possible that the bolt snapped and if that's the case then you should be able to just pull it out and replace the stud/lugnut.... or does it just spin freely in both directions? any resistance at all?
Old Jun 20, 2006 | 05:07 PM
mdlow87
it does spin freely both ways so i think its snapped off, but it hasn't fallen out yet for some reason. I didn't want to try pulling it out because i didn't know if it would cause any problems, but I'll try that out. thanks
Old Jun 20, 2006 | 06:27 PM
sir_nasty's Avatar
get some thin plyers or something and pull it out if possible. Then you just need to buy a new stud from an auto parts store and a new lug nut and you're set... I've broke one before....
adonus348
Nov 30, 2011 11:49 AM
wman
Apr 25, 2010 08:24 PM
Mike 68
Dec 19, 2008 10:33 AM
Tomsaccord
Jun 21, 2008 11:50 AM
chibiko
Mar 26, 2007 05:31 PM
