coilover sleeve advice
Old Mar 24, 2007 | 09:36 PM
steviebix's Avatar
Default RE: coilover sleeve advice
does anybody think tein s-tech springs will be too stiff for my car? it CAN handle it right?
[align=left] [/align]
Old Mar 24, 2007 | 10:36 PM
ORIGINAL: sir_nasty
If you were doing 90 and turning it would handle better with the camber settings you'll get from lowering the car.... but even for a daily driver if you lower it two inches it's going to kick those tires out pretty good and cause excessive wear on the inside of the tire, you can get away with it for a time, just rotate the tires at every oil change but it is going to wear out your tires more quickly.... I dropped my civic 1.5" and it gave me 2.5 degrees of negative camber which basically ment you could tell the tires were cambered just by looking at it... it's something that you can get away without for a time (maybe a year about 12,000 miles if you rotate the tires frequently) but eventually it should be corrected...
As for camber kit costs I've seen them anywhere from $60.00 to $400.00 it just depends on how much adjustment you need, basically I'd be sure to get one that can adjust the camber +/- 3 degrees, if it can do that then you should be fine... I'd consider asking a tire/alignment shop what they suggest and how much it would cost, then get the info on it and see if you can get a better price online....
Sir_nasty has the right answer here and it is up to you to take it for what it's worth..new tires every 5,000 mile do get expensive let alone alignments..
Get the camber kits my fellow member!
Good Post Nasty [8D]
Old Mar 26, 2007 | 11:21 PM
pwilkes3's Avatar
I don't suppose there's a magic number that you can get away with not messing with a camber kit are there? After how many inches drop does it become necessary, because i would like to drop about 1.5-2 inches.
Old Mar 28, 2007 | 05:37 PM
steviebix's Avatar
you will most likely need a camber kit after the drop goes below 1.5 inches. i just bought tein s-tech springs(2.0 drop front, 1.75 rear) and took it down to the local performance shop and the guy there said that a camber kit would be entirely necessary if i wanted full tire patch contact...so i ordered one...it was 200 bucks after all was said and done(s&h, tax, etc.)
goodnightninja
Jun 2, 2008 05:21 PM
T07N
Jul 17, 2006 04:06 AM
mdlow87
Jun 20, 2006 06:27 PM
tsblckcord
Apr 25, 2006 12:58 PM
#1hondaaccord
Oct 13, 2005 12:35 AM
