Front end sqeak
Old Jul 23, 2006 | 10:51 PM
cooiman5
Default Front end sqeak
I have a 93 accord that the front end sqeaks every time i turn or hit a bump. any ideas? i had the axles changed maybe 2 -3 yrs ago with new cv joints and boots. it's getting to be really annoying that i can't figure it out.
any help would be great to me and all the pedestrians as i can see their faces cringe as i pass by..
Old Jul 23, 2006 | 11:11 PM
mbo1985's Avatar
Default RE: Front end sqeak
I would suspect that the suspension bushings are wearing out.
Old Jul 23, 2006 | 11:36 PM
deserthonda's Avatar
lube the inner sway bar bushings and try ot again.........
remove the 2 ,12 mm bolts for the inner bracket, remove the bushings and apply grease tothe INSIDE of the bushing only, where it rides on the sway bar DO NOT put grease on the outside of the bushings.......
while under the car ,, as MBO suggested, chk all the other suspension parts.. lower and upper ball joints, ....
let us know the results
Old Jul 25, 2006 | 12:31 AM
Accordn2dis's Avatar
hey lemme know if it was your bushings or not, got the same problem
Old Jul 25, 2006 | 01:03 AM
poff1986's Avatar
Ball joints.....ill bet money on em too!
have fun with em too...ur gunna need an air hammer to get those removed...
Old Jul 25, 2006 | 08:56 PM
cooiman5
thanks i'll try it this weekend.
Old Jul 25, 2006 | 10:32 PM
corr04's Avatar
I had the same problem with my car. I just sprayed a lot of WD-40 on top of the upper control arm and around the ball joint and it went away! Might be a strut goin also!
jarede7
Dec 3, 2008 07:23 AM
corr04
Jul 25, 2006 11:32 PM
veedubxlr8r
Dec 17, 2005 01:04 AM
AccordColorado
Nov 7, 2005 10:39 PM
amp71
Aug 31, 2005 10:51 PM
