Lowering Springs Suggestions?
Old May 9, 2009 | 10:34 PM
marvinsae
Default Lowering Springs Suggestions?
I'm looking to drop my 2005 v6 accord coupe about a couple inches. So I've narrowed it down to three. Eibach sportline, Tein S. Tech, or H&R. Which would you suggest out of these three? Or are there any other suggestions you can throw at me? Which provides a more comfortable ride. Also, will i have to get new shocks/struts as well?
Old May 9, 2009 | 10:59 PM
finch13's Avatar
Which H&R springs? The Race springs are VERY stiff and definitely need GOOD shocks.
Depends on how stiff you want the ride to be (which is somewhat controlled by the shocks as well)
softest <-> stiffest
Tein S. Tech > Eibach Sportline > H&R Race
If they're H&R sport, they're a bit softer, but the race give a 2" drop or so.
And yes, anything over 1" or so will need aftermarket shocks to control the new springs.
I recommened Koni Sports, Tokico Illumina and KYB AGX.
Old May 10, 2009 | 09:39 PM
marvinsae
Is it a necessity that I purchase after market shocks? Would I be better off getting coilovers? what's the price dif
Old May 11, 2009 | 12:07 AM
finch13's Avatar
It all depends on which coilovers and springs you get, but in the end the set ups usually cost the same.
If you drop more than 1", I highly recommend you get shocks as well. Stock shocks or OEM replacement cannot handle the higher spring rates of lowering springs, so you will have poor handling and they will wear out much faster.
Do you have a budget in mind? Quality, lasting parts will set you in the $600 range minimum, there are a few things you can do to make it a bit cheaper.
What car are they going on?
Old May 11, 2009 | 09:58 AM
marvinsae
they are going on a 2005 v6 coupe. i wanna lower it about 2 inches but i wanna do it the cheapest way possible without damaging my car in the long run
Old May 11, 2009 | 02:22 PM
jdmaccord1215's Avatar
are you looking for just springs or coilovers?
Old May 11, 2009 | 02:23 PM
i had eibach sportline on my old acura CL, better drop then the pro-line and it stiff so your not bouncing around. had friends get the tein s-tech and were not stafied with the drop and went tech basic damper coilover kit for a better drop
Old May 11, 2009 | 06:58 PM
Question That's A Moot Question...
Iv'e used H&R, Eibach, DropZone(i like) , Sprint Springs (i like)+ there made by DropZone.,haven't ever use Tein Products...|(why pay so much money for something that you can get much lower price) .
Again..load rateing, driving style, cash in the pocket and what your realy want ..these are the questions you need to decide to do 1st..
Hope this helps you out...
Old May 11, 2009 | 07:25 PM
finch13's Avatar
Because you are paying for the R&D that went into designing the spring. With car parts it really not the same as, say, brand name vs. generic ibuprofen.
If you want to spend $50-100 less on springs that are going to provide bad ride quality, cornering characteristics, sagging, then by all means, go for it.
iskate604
Sep 8, 2013 07:29 AM
pimpp1184
May 4, 2009 12:06 PM
BostonPuppyDawg
Jun 15, 2006 01:39 PM
TedsF23accord
Jan 15, 2006 08:57 PM
Shocker
May 20, 2005 01:59 AM
