Mk1 Odyssey - Improve Steering lock & response?
Old Nov 23, 2007 | 04:12 PM
Ronnie101
Default Mk1 Odyssey - Improve Steering lock & response?
I have a 1998 Honda Shuttle (F23A7 SOHC VTEC), which is the UK version of the Mk1 JDM/USDM Odyssey. See eBay item 140182721157 for an example.
I don't like the steering and handling as 1. there is loads of understeer (particularly in the wet), 2. the steering lock is poor when parking in tight spaces and 3. you have to turn the wheel a lot to get the amount of corner turning you want.
In short, I think the steering and handling is intended for moms driving kids around town at ordinary speeds, not for open roads.
I don't know what to do about the understeer apart from putting super-soft tires on the front and changing the weight/moment distribution by putting 200lbs of lead inside the rear bumper - neither of which appeals very much as the tires are nearly new and it needs all the acceleration it can get.
However, I thought of a simple way of fixing the second and third problems - that is, to replace the arms from the kingpins to the steering-rack with (say) 15% shorter ones. This would mean that a given movement of the rack would have 15% extra effect on the direction of the wheels, and give 15% more steering lock.
I would have to be careful not to overdo it, so that I didn't introduce any bump-steer, but the car is used on tarmac 99.9% of the time anyways so I don't think that would be important.
Does this sound a good solution? Can anyone give me any advice about suitable and compatible parts and numbers - probably from the mid-90's Accord? I'm assuming that I won't have to completely dismantle the suspension...?
Thanks!
1998 Honda Shuttle (Mk 1 Odyssey)(F23A7 SOHC VTEC)
Pat61
Apr 20, 2012 03:21 PM
trystendaycey
May 23, 2011 10:43 AM
shimmyp
Sep 2, 2006 12:46 AM
vvenkat70
Dec 16, 2005 02:50 PM
nwurts
Jun 27, 2005 03:03 PM
