New suspension 2
Old Jan 17, 2008 | 07:35 AM
Chaqui04's Avatar
Default New suspension 2
I'm new with this coilover suspension set up can someone explain to me how to install them cause i see that the bottom sleeve is adjustable then i have three rings in the middle then the spring on top ? Does the bottom sleeve needs to be all threaded in ? remember guys what i'm trying to do here isto coverthegap between the fender and tire same on the rear. Thanks
[IMG]local://upfiles/8971/5F49B997598C407D974BAF3F93212FB6.jpg[/IMG]
Old Jan 17, 2008 | 07:42 AM
falkore24's Avatar
Default RE: New suspension 2
The installation manual should tell you how to set it up initially and also it should tell you that corresponding drop in case you want to adjust it some. Remember that the springs will settle a half inch after the first month, so don't go too low with new springs.
Old Jan 17, 2008 | 09:19 AM
j_man_honda's Avatar
That looks like the one for the front. The bottom just sits in a hole and requires no bolt, nut etc... Youll see what im talkin about when you have the old one off. As for the adjustment and sleeves, depending on how low/high you want the car, you twist the bottom part to the left to raise and to the right to lower the car. You tighten up the middle sleeve up to the top sleeve so the spring rate is messed with... DONT ADJUST THE TOP SLEEVE THAT HOLDS THE SPRING.... Heres a detailed pic
Old Jan 17, 2008 | 09:32 AM
BlkCurrantKord's Avatar
Jman's got it
Only thing I'd add is to turn the top perch a few turns if you can to help preload the spring. Thats what the manf recommended on mine.
Old Jan 17, 2008 | 11:31 AM
Chaqui04's Avatar
Thanks guys forthe help . Got one more questionso before i install them i adjust the sleeve's but how would i know if the car is to high or to low is this something that i need to be adjusting till i get it right ?
Old Jan 17, 2008 | 06:46 PM
ORIGINAL: Chaqui04
Well you can compare your old struts/shocks height to your new ones after you remove it. Then adjust the new one about an inch shorter than the factory one. This may or may not be the right amount of drop... But you can adjust the front ones when you get them on the car by jackingthe car up a little taking off some pressure and turn the bottom sleeve up or down. You just gotta keep letting the car down and see what the height looks like(very tedious and aggravating.... The back coilovers however you have to take the bolt out of the bottom to adjust it everytime...I wish I was there to show ya because its hard to explain
Old Jan 17, 2008 | 10:15 PM
Chaqui04's Avatar
Thanks j for all your help.
Old Jan 18, 2008 | 09:01 AM
falkore24's Avatar
J_man .... as BCK mentioned, in the picture above, the words "spring rates" should be replaced with "preload"
I'm a nitpicky bastard, aren't I! ..... just don't want others that are reading to learn about the systems to get confused
Old Jan 20, 2008 | 12:08 AM
tnguyen600's Avatar
hrmm...i guess all coilovers are different. on the teins, all you do is lift the car up, and spin the locks. nothing about actually rotating the bottom part as illustrated in the picture
Old Jan 20, 2008 | 01:47 AM
ChrisC76's Avatar
Yes tnguyen600, ours are not adjusted like this set here, I think ours are a bit less complicated and not to hurt anyone's feelings, but more user-friendly as well.
Chaqui04
Jan 27, 2008 06:05 PM
Chaqui04
Jan 17, 2008 05:49 AM
WifeysBrokenJetta
Mar 30, 2006 08:30 PM
aznnightmare9
Jan 16, 2006 08:27 PM
George Knighton
Jan 11, 2006 08:49 PM
