Proper Offset...
havent really been a big fan of offset until my earlier class of brakes n suspension...heck until then i didnt realize that i already knew what it was...i read a previous post where i cant remember who...but...sayin +38mm offset was too low....what would be a proper offset for new wheels...preferably 17" or 18", and also being said that....would deep dish wheels not co-op right with 6th gens?
"Offset" & "Backspacing" are really the same thing, measured from opposite directions on the wheel.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Hondas normally want an offset of around 50 or 55mm or so.
If you use a much different offset, you'll have to worry about the following things:
Too much offset = rubbing against the shock.
Too little offset = rubbing against the outer sheetmetal fender arch.
EITHER DIRECTION = incorrect loading of the wheel bearings.
heh...so basically the relationship of offset goes in this order if u were looking at the passenger side tire from the passenger rear door... +/- ..i got it now...
preciate it...i hear 225/45/17 is ok...
The rule of thumb is that an increase or a decrease in your overall tire diameter of more than 3% may affect your ABS if you have it..
So watch so that You dont create yourself a bigger problem..and dont forget about the newer cars with TPMS
00AccordLX5spd
Apr 16, 2007 12:18 PM
2007accord
Feb 14, 2007 12:57 AM
